HN7 to Windows 10
GEOFFDD
G'day All,
Has anyone had any luck getting a HN7 to talk to windows 10 given that Windows Mobile Device Centre doesn't work on W10. I purchased a map upgrade recentey & I've had no luck uploading it on to my HN7. I attempted to talk to Hema & unfortunately they were no help at all.
mauriceb
How to set the Dinosaur to Mass storage mode so pc reads it... Hema named it Usb mode. Tap setting /usb/select USB/ (Not Windows Syn) save setting. Plug into pc and wait for it to load. Or you have wrong / faulty cable if its not recognised. PS usb mode allows you to manually copy the map files to your device .The default location is on the sd card in the Folder called Oziexplorer Maps
