I have a HJ 60 with a 12HT and i am trying to find out if anyone has an answer to up rating the alternator for a unit that puts out more amps.
I believe that it is only possible to use the original unit or a new copy thats rated to about 80 amps. Due to the vacuum pump on the back of the alternator that supplies vacuum to the brake, clutch booster and engine shut off there is no other unit that can be used to replace the standard item that would push out over 100 amps.
I was also wondering if the vacuum could be supplied by installing some sort of other pump into the car so i could use a different alternator from a more modern car.
Any suggestions would be helpful in this matter.
