BonZa
got an old 1994 twin cab 2wd Hilux with the petrol 22R motor
have a problem starting it.
stick key in ignition, turn ignition on and all the instrument lights come on ok, turn further to "start" then nothing, dead silence. the starter motor doesnt crank, no click absolutely nothing. try again a couple of seconds later then the starter motor fires up and the engine cranks ok. been doing this for a couple of months. seems worse when its real cold and this morning was down to about 5 degrees. sometime it takes about five goes befor it decides to crank
things done so far, a new ignition key barrel, a new ignition switch, checked battery terminals and cleaned, un plugged the stater motor solenoid and hot wire from the battery and cleaned, and this morning took out the starter and bench tested. worked perfectly every time. bolted it back in again and tried with the key, nothing silence. tried again and on the third go the starter motor decided to crank and fire
got me beat. any clues out there
