Hilux Rear winch
hiluxjim
Gday people,
just thought i would use your brains if you will let me. the other day i got stuck in a hole and winching forward further into the hole was my only option because i was by myself, a light bulb popped up in my head about a rear winch option because if i had a rear winch i would have been out of the mud in less than 5 minutes compared with the 3 hours i was left stuffing around trying to go forwards. Question: Have any of you hilux owners or similar ever played around with the idea of making up a mobile/removable winch system for the rear end and can you please help shed some light on the matter (or as ive just joined 4x4earth point me towards any previous posts of similar discussion) cheers Jim
NIAL8R
i think most just opt for a hand turfer mate or a 2nd truck in toe always helps :D but it was me and by the sounds of it you would have got ya self all muddy i would have just run the cable under the diffs and out the back of the truck and winched away providing you had something to hook up to !
BILLBY
seen
I have seen a a hayman reece type adaper plate that you can mount a which and used anderson plugs for power supply ,take it off throw it in the back or even put on another vehicle they were on sale on the net some time ago
:cool:
Croozer
Yeah Tigerz make a hayman winch kit and it slots straight in your tow hitch. We used one a while ago and it worked a treat. Just remember a rule of thumb!! Its better to have another rig with you when you venture out. Always good when you yell out "help" that there is someone there to hear you.
Watt
winch in the back would be easier but usually you want to head along a track so pulling out backwards is only a short term solution.. still gotta get through the shit sometime.
Big Rig
You can winch backwards with a winch on the front of the truck so long as you have the correct amount od blocks and shackles. If you get confused about how don't worry. It makes a good conversation point when your on the piss at Cape York:eek::D
On the other hand and I in no way endorse this or recommend anyone to do it - I, once in a life and death situation did run the cable back under the truck and winch backwards like that but I must stress this was an urgent situation and there was no other way. I took all the necessary safety precautions that I could and It paid off and saved my family AND truck.
hiluxjim
cheers guys, ill have a look around for that plate, and yes i thought about running the cable underneath but there was absolutley no room under the front bar to slide it under. i was in the hole pretty bad, :) hand turfer sounds tiring, however i think thats going to be my easiest and smartest option. less weight, cheaper, more storable and probably more uses to it than just pullin me out of a mess i should have avoided in the first place, cheers Jim
Yeah i spoke to a member about this on the recent trip away,even if you could run a channel so the wire could stay in to the back lol...anyway the tigerz option is the best option and i like the idea...
CAMPDOG
There's a bloke (Steve9R) on NewHilux.net that has a removable winch on his '06 Hilux. It's a 9500lb Mako winch from Avenger4x4.
This is what Steve had to say........
Steve9R said:
Here's mine..
I have a custom front hayman reese towhitch and HD anderson plugs front and rear so i can move the winch to the back or front in its carrier.. plus it means i store it in the tub when im offroad so it doesnt get unneccessarily muddy / wet etc and should prolong its life.. and i can take it out when im city commuting, thus reducing weight..
works for me..
Steve
Joel
