Boycebag
Hi All, Just an info item. I have been chasing a rear end shimmy for about 9 months. Came in at about 80kph and "went away" at 110kph (just could not feel it). Have a 4" Snake Racing Lift and 33s - just great but was not causing the problem. Tail shaft unis all good, centre bearing changed as sus still no good, balanced the daylight out of the wheels. Finally went to Sydney Driveline Services at Greenacre with tail shaft. Doug was great!. Spun up the shaft and straight away found the front half shaft was bent - not dinged but bent. Most likely happened when the Luxxy was on the dyno and was over torqued. It is a 3.4 petrol with a TRD Supercharger and makes lotsa mumbo. Careless Dyno operator using poor methods allowing the dyno to back drive at excessive force. Any way Doug straightened it and balanced it just fine now all is good.
