Hilux LN167 pulling to the left!
peyotedub
G'day all!!
Got a 01 hilux model LN167 IFS, ive been having problems with it pulling to the left for some time now! im running 15X8 sunraysia rims with 33X12.50 Federal Couragia MT. Ive replaced the tie rod ends front wheel bearings Idler arm and got a wheel alignment done and its still pulling the the left. Im not sure what to do now or what to look for what could be pulling it to the left! if anyone has any thoughts would be greatly appreciated.. cheers PD
03hilux
Try swapping the front and rear tyres on one side only. Sometimes the belt in the tyres cause " radial drag" caused by incorrectly stored or transported. can also be manufacture fault. if one side doesnt work try the other. it could be caused by only one tyre.
Ehboy
Mate I had a hilux and the brake caliper pistons tend to seize:confused:, I'm not sure if this is your problem but if the right one is seized it will pull hard to the left under braking. Also if the left one is tight and not releasing too well it might cause drag and a slight pull to that side. If you have tried everything else this might be worth a look.
peyotedub
thanks for the help everyone.. ended up being my leftside wheel was back making it pull to the left! i thought they would of picked that up on the wheel aliment??
cheers everyone PD
I_Lux
cheers everyone PD
I have same issue what was the fix?:confused:
