ferential Codes
Size of Diff
A=138MM , B=145MM , C=6.25” , D=6.662” , E=7.1” , F=7.5” , G=8’ , H=9” , J=9.25” , K=9.5” , L=10.5” , M=12.5” , N=13.5” , P=14” , Q=12” , R=162MM , S=6.38” , T=6.7” , U=6.0” , V=10.6” , W=15.5” , X=142MM , Y=158MM , Z=202MM
Ratio
01=3.300 , 02=3.360 , 03=3.545 , 04=3.556 , 05=3.700 , 06=3.889 , 07=3.900 , 08=4.111 , 09=4.222 , 10=4.275 , 11=4.444 , 12=4.625 , 13=4.790 , 14=4.875 , 15=5.125 , 16=5.286 , 17=5.600 , 18=5.714 , 19=5.833 , 20=6.167 , 21=6.667 , 22=6.780 , 23=6.833 , 24=7.640 , 25=4.556 , 26=5.571 , 27=3.364 , 28=4.300 , 29=4.100 , 30=3.727 , 31=3.909 , 36=4.778 , 37=3.583 , 39=3.154 , 40=5.375 , 41=3.308 , 42=6.500 , 43=3.550 , 44=3.214 , 45=3.533 , 46=2.929 , 47=3.944 , 48=3.356 , 49=3.729 , 50=3.400 , 51=3.736 , 52=3.722 , 53=3.250 , 54=3.941 , 55=3.333 , 56=2.821 , 57=4.058 , 58=3.238 , 59=3.234 , 60=3.519 , 61=2.724 , 62=2.892 , 63=2.655 , 64=4.312 , 65=3.873 , 66=3.071 , 67=3.526 , 68=3.095 , 69=4.176 , 70=5.857 , 71=2.962 , 72=3.949 , 73=4.285
Different Models of Toyota could be
32=6.591 or 4.807 , 33=7.503 or 5.583 , 34=6.781 or 4.786 , 35=7.636 or 5.600
Pinion & LSD
2 = 2 pinion open diff
3 = 2 pinion LSD
4 = 4 pinion open diff
5 = 4 pinion LSD
Other verification of either 2 or 4 pinion diff is,
On a 2 pinion it will have 3 fins either side of the outer case.
On a 4 pinion it will have 4 fins either side of the outer case.
