hilux brake upgrade part 1
typhoeus
well, the brakes were getting to the point where you would have to stand on them to get anywhere near locking them up, and after aan inspection, found the discs were worn past minimum thickness. So I figured if I'm going to replace discs, might as well see if I can fit bigger/ better brakes. My RZN169R came with20mm x 289mm front discs an sw12 callipers. As you may know, a common upgrade is to fit surf brake parts which bolt up to the hilux hubs & stub axles. After some careful checking, I ordered a set of surf discs, which are 25mm x 291mm
typhoeus
Then I sources a set of s13wb callipers from up gosford way, These calipers have the 89mm or so bolt spacing to suit the hilux but have 45.3 mm pistons like early landcruisers. (The sw12 calipers have smaller pistons.) As you can see, they weren't in the best condition, but for $55 for the pair, I was happy to grab them at that price, and recondition them
typhoeus
So the last couple of days after work has been spend cleaning up the calipers fitting a seal kit and prettying them up a bit
typhoeus
Now, there are 2 types of pads which fit this caliper, and I read on other forums that one type overlaps the disc by 5mm and causes a problem because this reduces the swept area in contact with the disc, The correct ones are FDB1502. (ferodo catalogue) whereas the FDB1504 are for the landcruiser caliper. The metal backing plate is identical, the difference is in the positioning of the pad material. You might be thinking why didn't I just put larger diameter discs on, well, that would mean fitting bigger wheels to fit over the discs and callipers, so I didn't want to go down that road.
Anyway, tomorrow ill fit up the new rotors, and the reco calipers and see how much difference it made!
typhoeus
So, today I jacked her up & started, here's the original brakes, looking a little worse for wear
typhoeus
The discs are held on with6 bolts which I expected to be tight to get off, but it came apart quite easily, and the new discs fitted straight on
typhoeus
Free wheeling hubs. . one gave me trouble ( something had to go wrong ) the spring which holds the locking gear got bent up somehow, but I carefully bent it back into shape and all was good
typhoeus
So, all back together and a quick test run later and the brakes are definitely better, I expect them to improve even more when they bed in a bit. I am also thinking about fitting a double diaphragm booster as well later . And to finish the job, The sticker on the back window. . .!
Arch
Hmmm, I think I've just found my next upgrade! Great article @typhoeus, thanks.
P.S. I don't suppose you recall the part number of the pads?
typhoeus
I can't remember , that was 5 years ago, but further up I mentioned FDB1502,so that's likely the part number..
