Hilux- Brake caution reset
c_lewien
Hi all,
I replaced my rotors tonight and fluid level went to low. Bled the brakes and topped it up to full but light won't go off. Is there a reset? 97 model
Sorry posting on phone
Thanks
Cam
ERASER
Nope no reset. Make sure the wires that go to the cap on the brake reservoir are connected. Also make sure the float under the brake reservoir cap slides up and down freely.
Alien d2
Does the master cylinder have a switch on it?
In days gone by I've seen this switch "trip" as one side of the master cyl. pistons run low on fluid.
The fix was to remove and refit the switch but worth cheacking with those who know these rigs first.
Yogi
It's normally the float in the reservoir that sticks, I normally use a cable tie to give it a poke and then it's OK
Mike
