hilux 33" tyre fit
RBJET
2" lift and different offset wheels from memory. A Google search should give you all the answers you need.
mac_man_luke
Also check you might need to have the body mount modified, i know its a common mod and i think its to stop the larger tyres hitting it.
In my opinion it would be worth considering replacing all the usual stuff that wears out in the front suspension ball joints, bushes etc as they will be under a lot more strain especially with wider tyres now, also a good idea to get wheel bearings checked or replaced. It may sound over the top to some but if you start with everything in good condition you will have less chance of getting a failure out in the bush. Also some better brake pads some time all round to help with stopping power as it won't be as good.
Don't forget to check your speed with a gps after the tyres are fitted the speedo will be out.
