High Clearance
dochol
Banned
Would like to know opinions on what you would consider a high clearance vehicle. Would say a MK Triton with a 2 inch lift be considered high clearance.
Doc
TheLocksmith
I was told any vehicle that has been lifted was classified as high? Not that I know, just what I was told.
Was going to add a 2'' lift but was told my warranty will be voided by Nissan if the Patrol was lifted?
In saying that the Patrol has a 210 clearance, how much higher would 285/70R17 make it?
Ant
daddygav
I would consider an mk with 50mm lift and 33" tyres to be high clearance. As in my case, mn Triton with 25mm lift and 32's, i'd call it medium clearance.
I find I knock the nose and drag the diff a bit, not unusual for a Ute, but bit more height from springs and rubber combined would be nice.
PJR NSW
Banned
Aren't they, Government bodies and motoring groups like the NRMA etc, talking about high clearance "as standard" out of the factory. A mini with a 5" lift could be said to be a high clearance car. But is it? Not on your nelly. Even at 5" it would have had trouble on many roads that we even took our Holden. And the the Holden wasn't a high lift car either.
It also comes down to approach, ramp over and departure clearances.
I would consider a standard Patrol and a Landcruiser high clearance cars. A territory - No. Yes there are others but I just grabbed the two most prominent car as examples.
Phil
tankbloke
I would agree with daddygav, the bottom of the diffs are the lowest part of your vehicle, and the taller the tyre, the more real clearance you get.
So I guess what I am saying is, that I would not consider a vehicle with a lift only, high clearance.
daddygav
I wouldn't consider any vehicle high clearance straight from the factory, although patrols and landcruisers have the most. A decent lift and bigger tyres will always be needed IMO.
I reckon if you could get 3 inches of lift and 33's under a territory and still be able to drive it, it'd be high clearance.
PJR NSW
Banned
I wouldn't consider any vehicle high clearance straight from the factory.
That is stretching it mate. Are you including all SUVs as well and don't forget the 2WD fraternity. Surely there is a difference. Some are and some aren't. The blanket statement is too wide and inclusive of ALL cars.
Phil
daddygav
Phil
You're right, I guess it depends on the context of the original question.
Wether you compare clearances between ALL road based cars, or from what I thought, vehicles intended for off-road use.
Would've thought clearance only really comes up as an issue when driving offroad, so didn't really consider 2wd or SUV types. I still think for the majority of tracks, the clearance from a factory spec patrol, or hi lux, triton etc is only just gonna escape a few scrapes.
PJR NSW
Banned
True about the context but I still wanted a little clarification. We used to take our holden where a lot of people would never take their awd's. Chasing surf back in the late 50's and early 60's when there were heaps of "vigin" coastline to be had.
We followed a Forrester in to Big Red a few years back when the detour down to the SA border was in use. The poor old Forrester had trouble several times with the center sand hump. He had to turn around and go back. We on the other hand no hassles with a standard height car.
The only place that I have had an issue with approach clearance was going down Palm Creek and Gunshot Creek on the Cape Your OTL track. Departure clearance is not the best though. But very easily "managed". We have never had a problem with clearance in thousands of kilometers of tracks from the Vic high country to the tropical water washed tracks and the deserts.
No lift at all. Just a spring adjustment.
Phil
daddygav
Wow, that sounds awesome Phil, I guess driver skill and experience makes a huge difference to.
In my case, the bash plates, side steps and tow bar of my stock triton got a good workout before the barwork, lift and bigger tyres went in! and even now I can easily get caught up in bigger ruts
PJR NSW
Banned
I wouldn't put myself on a podium for best driver of the year. But you are spot on as far as experience and skill is concerned.
As for bar work etc. We trashed the side steps but since we got a set of steel steps they don't even seem to be touching the ground. Work that one out????
You want high clearance then how would you like the one below. I drove one like it for two years during nashos. Where the tanks went so did we. Awesome grunt and everything.
Phil
In saying that the Patrol has a 210 clearance, how much higher would 285/75/17 make it? Think I can only go 285/70/17 before a lift kit is needed?
Ant
That's typical of Nissan to say that were you looking at one of the kits they have on display in there spare parts section or from another company. They send customers cars off for suspension mods and for added accessories quite often to 4WD outlets before there picked up by the owner and they put there own mark up on it as well. I don't think they could void a motor and electrical warrenty for a suspension lift.
dochol
Banned
Phil[/QUOTE]
Hi Phil
Had no trouble at Palm Creek with either approach or departure, Gunshot scraped my back end but luckily have a steel tray
Doc
PJR NSW
Banned
Hi Phil
Doc
At both places we just got a bit of mud on the front. Neither a real big problem. Other than that the car has been excellent. Saved heaps not getting any "lift" done. And don't attract attention either!!
Phil
peterfermtech
I drove most of the vic alps in the early 70's in an HT. With LSD and snow chains you could go just about any where except for the steep climbs. Even then its amazing how many short steep climbs you could get over with the help of a coulple of fit young blokes. The difference then though was that there were very few 4WD's about and none of them had powerfull engines or big tyres so clearance was not a big issue. And if a landrover had dug out ruts you could straddle them anyhow.
regards
PJR NSW
Banned
And in about 1973 I pulled an old Toyota out of a bog at Womboyne Lakes with my HK. And right next to the camping ground. Shamed the hell out of him and won a carton of beer as well.
We also went to a lot of places without a lift and just the old LSD in that car. Mainly looking for surf on those boggy beachside tracks, "just over the sandhills".
Phil
waz
Isn't the only way to increase clearance with bigger tyres? Suspension lift will increase approach, departure and ramp over, but your diffs will only rise by half of your tyre diameter increase.
Purely in terms of clearance, a stock triton is only about 20mm short of a 200 series. But the 200 is 90mm short of a stock D4. The cruiser and patrol are not even close to the most clearance.
TheLocksmith
So your saying (Stock) a 200 series has 225mm ground clearance, triton has 205mm and a D4 has 315 and the Patrol has 210mm (approach angle is 37 degrees, the departure angle is 31 degrees and the ramp-over angle is 27 degrees)
Patrol Y61 measurements
?????????? ??????????????? - ??????, ?????????????? ???????????? ? ????????? ?????????? — Articles
Old Prados have 190mm and the new prado (2010) has 220 mm of ground clearance compared to the troop carriers 215 mm of ground clearance
03GV
Is the original poster asking what is classed as a high clearance 4wd, because alot of parks say high clearance vehicles only for certain tracks? If thats the case, its usually just to keep out sedans and the like. You'll find they class all "true 4wds" as high clearance.
