Hi LIft Jack issues
Nessie
So my hi lift jack will lift the car - but I can't get the <insert expletive> thing to lower! Any tips / ideas on what is probably a maintenance issue
frosty
The shear pins are worn. Buy a service kit. New springs, pins, etc.
Have you cleaned and lubed it by the way????
Nessie
clean, lube - gads no!
I've used it twice, it hasn't been offroad, and I don't think the pins would be worn after 2 uses - it is lmost as though it has slipped past one of the pins but I can't get it to shift - I shall go in search of a closeup so i can check location of components
Vegetoast
When mine gets stuck I spray the pins with WD40 and it works fine. later I give it a clean and a bit of grease. as Frosty said check your pins for wear anyway.
frosty
Big hammer!! Give it a tap up and down. When mine jams up, I launch it and comes back workin again. (flog the crap out of it)
kremin
Those high lift jacks are an accident waiting to happen. They can be handy, but they are very risky. Be careful and don't trust it as a single support; always back it up with something. :(
88hilux
pull the handle down really quickly with both hands on top of it (as it may spring back up pretty fast) that usually works for me if it won't go down.
I hate the ******* contraptions,sure they hav there use's but DONT underestimate how dangerous they can be....
Pure Yobbo
Each to there own. High is Frosty's best friend....
I personally really enjoy the rattle the jack makes will attached to my roof rack on a dirt road :rolleyes::rolleyes:
frosty
Great tool if you treat it with the resect it requires!
Yep, used mine once or twice. Lifts cars, pulls tent pegs, hammers star pickets, winches, ( thats why I got a "big Rwig"!!) very slow!!
I'de be stuffed without it!
Vegetoast
Hey Frosty I use mine for all sorts too but I cant stop star pickets from turning into bananas. do you have that prob or have you got a tip. I'm asking cause I pull alot star pickets and the misses get the poops with me for bending them
CHUAH
I believe it can only really "step" back down under load... otherwise if not underload may just stay still however will drop straight down once you move the lever..... under load, you can jack it back down etc....
John U
Sorry for the grave dig but I’ve just done a bit of research which might add to this thread.
For lubrication Hi Lift recommend ‘After cleaning, lubricate the jack using light penetrating oil, or a silicon or Teflon spray’
Page 16 at this link details the parts to lube
https://hi-lift.com/wp-content/uploads/2016/07/First_Responder_Instruction_Manual_English.pdf
Some of my searching advised against WD40 because it wasn’t a lubricant.
I used CRC tackle guard because I had it in the shed and it ticked all the boxes. Not sure if it’s just rebranded wd40. The jack is running smoothly now.
Hoyks
For anything like that I prefer a silicon or teflon spray as although spray oil can free it up initially, it can also attract dust and clag it up long term.
A splash of water can also help provide just enough lubrication or wash the dust out if you stuck.
and this is why you maintain your gear, letting go and manually releasing the lowering dogs is ill advised.
He should be better at using it next time, not get crossed up and lean over it.
