Hey guys was wondering if anyone could give me any information or feed back on hi lift jacks and 12volt air compressors, what are the best brands, most reliable and so on. My mrs an i are planning a trip touring WA top to bottom any other information would be awesome!!
re: feedback on hilift jacks. if you r new at this 4by thing, be very carful with a hilift.
they can b dangerous if used incorrectly!!! unless u have propper lift points for said jack(the t section in front and rear bars) dont use it. they r 2 unstable, unless u know how 2 realy use it.
a safer lift is the hydro jac. much safer and easier 2 opperate.
lifting points r not as critical, as the unit does not sit as closely 2 the body as the hilift.
still, u need 2 be very carful with the hydro. (its around $600)
i have both and use both. they all have their pro's and cons.
as my truk is lifted 8inches with 36's these r the only jacks that will (just) pick my wheels off the ground.
i would suggest if u only have around a 2inch lift, a 2ton bottle jack and a good sole plate is a far better and more importantly, safer option 4 u.
hope this info helps, cheers 345 chippy
