Hey there Danny Boi, just looking to see if anyone here knows how to cook a good Snapper outdoors and you just happened along as I thought of it, so I guess it's directed towards you, hoping for a good answer here, cheers
Hey Grumpy, I think I can help you out with this one mate!
First things first, you need to turn your grill onto a low heat. Cut some lemons & red onions into medium sized slices (you will need the same amount of slices for each side) then place in the fridge. Next you need to make garlic butter, minced garlic is fine as long as it is a decent product, but fresh garlic cloves are recommended. Mix minced garlic through the butter & add freshly grated sea salt & fresh cracked black peppercorns & mix again. Grab a bunch of flat leaf parsley and pick off the stalks, wash, rinse, drain & dry parsley. Rough chop & throw into butter, mixing once again.
Grab a large piece of foil, and a piece of baking paper the same size as the foil. Place the shinny side of the foil facing you on the bench. Put baking paper on top of the foil, and then overlap your lemon slices in the middle of the paper. Do the same for the onion, now throw a few capers onto the onion, followed by the garlic butter.
Wash the fish inside and out, pat dry with paper towel & score both sides of the fish (Not too deep) with a sharp knife. Season both sides with freshly ground salt & pepper & place on top of ingredients. Reverse procedure on top of fish, wrap tight with baking paper then foil.
Cook on a low – medium heat for 35 – 45 mins, turning over every 5 mins, this way it cooks evenly.
Hope this helps Grumpy..........
Cheers Danny Boi
