Hi all, new to this - headin to Robe on friday
Benny4x4
Anyone got any tips for robe tracks?
i read allot that they are prety soft sand and am pretty much guaranteed to be bogged.
problem is, i'm heading down with my GF and no one else in a 4x4... any recommendations?
i got a 97 pathfinder with 2 inch lift kit and just had installed front auto lockers (LOKKA brand which i hear dont work when you turn the steering left or right) on the hope that i can do a little more than i could before and not get bogged..
also have compressor (to drop pressure to 15-20psi) but my AT's (all terrains) are not exactly 100% tredded up, they are about half worn so I'm kinda worried bout that too.
Boofdtl
Hi mate we will be down there on sat with a heap of 4wds were are you staying at lots of good tracks down there we go every cup w/e...
80lover96gxl
Hi mate, robe is an awesome place but caution needs to be shown on alot of the tracks down there.
Your at's that are half worn will work in your favor on the soft sand enabling you to get up on top and float over the sand rather than pushing your way thru it.
A sand flag should be mandatory down there, lotsa blind cnr's and crest's on the dune tracks behind the actual beaches and the possibility of a head on is very real.
Errington's beach is probably the most notorious down there, super soft sand almost like shell grit can bring you unstuck in know time, dont be tempted to go closer to the water's edge where the sand is normaly firmer, it's not and you'll end up in all sorts of strife.
A long handled shovel, rated recov gear and points on your vehicle is also a must, take two snatch straps if possible incase you need to join the two togeather, a set of maxx traxx or those new tread recov trax would be handy if going solo but you'll find there's normally a few 4b's running around, you can pick em up on the uhf fairly easy if need be.
Due to the weather warming up abit now the sand usually tends to get abit softer so keep this in mind.
There are some awesome dunes down there but dont go into the miscellent buggy club area as this is off limits, especially if there's an event on, you could get in contact with the buggy club and see if there is an event on and if not you may be able to access the dunes, just remember dont drive accross the dunes only up and down and be weary of the other side of the dunes aswell some are easy to get up but can almost be vertical on the other side and can lead straight back up leaving you stuck between a dune and a hard place so always check the other side before you launch up and over one.
Some good fishin down there off the beaches and little coves, just look for the good gutters and you might just catch somthing.
You can pass through Nora Carina (small fishing village ) just be sure to close the gate behind you, watch out for the nudie beach, normally a couple of old shrivelled snags lying around and not much else.
Dont be afraid to drop your tyre pressures down to 12 psi if your finding yourself in a ot of bother, iv gone as low as 10 psi just to get out of a sticky situation, just avoid sharp turns when running that low.
Hope this help's and have a great trip.
cheers,
Brian.
Benny4x4
I'm staying in a rental holiday house my gf booked so i'm not sure where exactly it is.
Thats heaps of info - thanks..
I just bought some max track things just incase from Autobarn - i figure the more back up equipment i got the better off i will be being on my own.
I am definatly taking rods down too and was planning on checking out the nora carina and stopping to throw a line out where ever i can.
I had the local council email me a whole lot of maps etc for 4x4 tracks which will help too.
thanks again.
Benny4x4
oh,
also picked up a couple flags i'm going to strap to a 20 or 25mm length of conduit to my car -somewhere dont have a bull bar and may have to strap it to the side mirror or something
goanywhere
Hi Benny4x4. That's good advice from 80lover96gxl, but just an additional point. If you've got front lockers they are both a help and a hindrance. If you plan your attack on a dune to make it as straight as possible, and if you have momentum when you need to turn, they will help keep you moving and get you through the sand very well. However, if you try to do too many turns at slow speed they will cause your outside tyre to under-rotate and make bogging easier. If you do start to slow down and you think you might get hung up, try to stop before you get bogged. You can always (normally) reverse out and give it another go.
On the beaches, if you do get stopped (not bogged) in the sand you can try this little technique I was taught one time I got stuck on a beach:
1. When you feel your car starting to labor and you can't maintain momentum, let the car come to a halt rather than trying to 'grunt' your way through. If you are stopped and you keep your wheels spinning you will just go down to your floor and your situation will be much worse.
2. If you can reverse without spinning your wheels, reverse a couple of metres back into your tracks, then forward back to where you were stopped, then back again. This will compact the sand a bit and allow you to get momentum up again. Then drive forward quickly over your tracks again. You should be able to get enough speed up to make it through that ultra-soft stuff and keep going.
3. You might only get a few metres ahead of where you stopped before, but if you repeat this process each time you get stopped you will make a few metres each time. Usually the ultra-soft sand areas are only 50-100 metres at a stretch, and you can get through those without bogging, and then when you reach a bit firmer sand you will be able to get through and keep going.
4. If you find you can't make much more headway doing this, drop your tyres a few psi and repeat the process. I have never been totally bogged in sand (even loose shell-grit) when I have used this technique, but I have had to go down to a little as 6 psi to get out of one spot down along the beach there near Carpenter Rocks. (Just don't make any sharp turns when your tyres are under 10 psi or they can roll off the rims.)
It's a classic 4wd trip that one, but if you try to tackle the sand the way you would mud or rocky tracks you will get into trouble really fast! ;)
Benny4x4
BOOFDTL
Got your PM and can't reply for some reason but as a reply-
Yeah sounds awesome. i'd probably prefer to go with 'others' with the sounds of some of the tracks, I kind of dont trust the really soft sand too much and haven't had enough experience on tougher tracks.
I will give you a buzz when we decide to head out on saturday. I know we'd be more than likely plan on waking up and heading out for a coffee and breakfast first so it'll probably be around late morning before I call so dont wait for us - I can come find you, i'll be taking 2 ways also, only hand held so not sure how they'll go.
(I have a gold pathfinder with two trucker girls on the mud flaps if you see us around.)
Were only down there till sunday and i'm going to try fit in some beach fishing.
GOANYWHERE
Thanks for that, i figured i'd be buggered trying to hill climb and turning at the same time but the advice and steps you have given are a help - i didnt' ever consider the 'hardennign of the sand using your own tyres" to get a good run up..
Heaps of help everyone - Thanks!
Kermit
Welcome to Earth
Great advice from everyone.
Only browsed through quickly and didn't see important items.
Take a Mate with another 4B.
We just did the Limestone trip and to have another 4B or a half a dozen people to assist you to move forward is a absolute bonus.
If Ur wheels start to spin, stop and evaluate the situation.
Check the tide times and hit the beach at either high tide or as it's just dropping.
Don't want to get caught to Ur belly in soft sand with the tide comming in and nobody to help.
Hate to see U lose Ur 4B to the incomming tide.
If U really have the need to do it by Urself, KEEP ABOVE THE HIGH WATER MARK as much as possible.
Do U have good RATED Recovery Points both Front and Back.
A good UHF Radio helps.
PLEASE Remember to ERRR on the side of Safety
Take care and let us know how Ur Trip goes
Benny4x4
Thanks Everyone,
all info gave me more confidence with the tracks.. my pathfinder had no problems at all as it was but great to have feedback and help in situations before we went.
already looking to head back there at the end of the month for another run..
