Hema Maps on Android tablet & then onto SD Card
knakkers
Hi,
I'm a novice when it comes to downloading maps, example Hema Maps onto Android tablet device. Always used paper maps in the past.
I know this topic has been discussed many times.
I've just recently purchased the last Samsung Galaxy Note tablet 8.0.
I've downloaded the free app Memory Map. I now cant decide if I should go 1 of the Hema map packages of all 4 regions, or 1 of the VicMap 25k Topo packages??
Both have a free 10 day trial period.
Also is it possible to download maps on to tablet then transfer on to 32GB SD card so I can save the memory on my 16GB tablet??
Any info would be help full
Stuart
Maurice, Knakkers is referring to Memory map, not ozi.
Stuart
you can copy any or all of the maps in the SD card. When you do that delete the memory map folder in downloads and make a new one in the SD card. This is what I did and it is on the Memory map website. Also, although the Samsung doesn't say it, if you get a Sandisk SD card, it will support 64G.
As for the maps download the trial and try them. Also download the topo 250K which is free, it has more detail than the Hema maps and is a great map for Australia wide.
prawns
I got scared off the sandisk cards after reading about all the failures they had with their 32 and 64gig cards recently (they admitted a manufacturing issue and replaced them under warranty, kudos to them but it doesnt help if you lost all your data)
Ended up paying nearly twice as much for a genuine samsung 64gig card arghh. The sandisk cards with the issues were apparently made at the end of last year - but it still seems these faulty cards are getting sold from stores with a low turnover (old stock)
somthing to keep inmind anyway I bought mine a month or so ago and looked into it back then (you should be ok by now though surely, just with my luck I didnt risk it lols)
