Help with Prado dash lights keep coming on and off
Shire
Hi
I have a 2008 Prado the brake light and a few other lights on the dash have commenced coming on I have taken the fuse cove off near the (r) leg but have no idea how to judge the fuse to be replaced any one have any ideas?
dochol
Banned
Hi welcome to the forum
Try posting in the Tech section under electrical, you might get a better response
Doc
prawns
....but have no idea how to judge the fuse to be replaced any one have any ideas?
use a multimeter (or you can buy one of those electronic fuse checkers I assume pretty cheap, they light up a light or make a tone if the fuse is ok) - else you gotta pull them out one by one to check
Those 2 bits of metal inside the fuse should be joined together else its blown, check them all while your there, and make sure you have some spares
Generally the fuse information is on the plastic cover you pulled off - generally have a diagram showing which fuse does what
I should mention, if you pull the fuse for your stereo you better know the code first......
