Help with driving light selection
Horn_Bee
Hi everyone,
I've tried to search for an answer to my question but so far haven’t been able to find anything that covers exactly what I need; I do however apologize in advance if this is an obvious question…
I am about to enter the daunting world of aftermarket driving lights for the first time and I need some advice. I drive a 2012 GLXR Triton, and want to set up a light system that covers both low speed 4x4 driving in the bush, as well as night time touring on remote country/outback roads.
The combination I have pretty much decided on is as follows:
* 2x 200mm XXX HID lights on the nudge bar HID Driving Light - 12V/Spot/200mm
* 1x 30” Rigid Industries LED light bar on the roof rack LED Lights - E Series LED Light Bars - the brightest, most efficient LED lights in the world | Snake Racing 4x4 Accessories Superstore
This should provide great visibility and depth off the side of the road and directly in front from the light bar and good long range visibility from the HIDs.
What would you guys recommend in terms of the HID light combination at the front? The combinations I am currently considering are:
* 1xpencil beam and 1xspread beam
* 2x pencil beam
My only concerns are that if I chose a spread/pencil combo that the LED bar will basically neutralise the light emitted from the spread beam HID and leave me with diminished long distance visibility. Alternatively if I use two pencil beam HIDs will I be left with a poorly lit section between where the LED bar loses range and the pencil beam HIDs come into their useful range?
Either way I am sure the light system will work fine, I am just trying to maximize the effectiveness of my purchase.
Does anyone have any advice/suggestions?
Mick
Hiya Mick
All i can comment on is Ive had the Lightforce 100 watt 170's on my vehicle about 5 years now..I reckon there been through at least 300 rivers crossings..Never had one issue with them..You can turn them around to adjust pencil or spread beam...Also i can put other covers on mine..Like Yellow,Blue (softer on the animals eyes if you want to go out at night and check them out..
When wiring make sure there not wired to your high beam..You can buy a harness to sort this out..Also make sure that the connections from the light to the wiring are waterproof connections..
I use the mouse on and off switch..Its been sikaflexed to my dash and hasn't moved..Other stuff falls of due to summer and heat...Unless you screw it which i dont like too..
Sidewinder Harness
Goodluck in your choice...
pencil and spread, the spread will give you better low lying visability and the bar on ur roof will do a wider angle and higher up. the one pencil will be enough to penitrate and give u distance.
Patrolin
Hey mick,
I've got 2 xs9000 pencil beams and 40" rigid industries. I did start of with a pencil and flood but switched to 2 pencil and found this works better for me.
I think the bar might be better than you think at medium distance. I don't have any dull spots at all and am not sure why most people think the bars don't have any distance capability as mine throws well medium distance.
In case you're thinking of rigid industries copy's... Don't. My mate bought 3x 30" copy's for his rig and ended up replacing with the real deal after been very disappointed. The rigids are heaps brighter than the copy's.
1tufftruk
Hi mick
I have 2, 7" 55watt HID on bullbar both pencil and 2, 55Watt HID pencil on the headboard as well as 2 55Watt HID spread on the headboard and m8 believe me when i hit those suckers it's like a mobile lighthouse
