Help with crank sensor wiring please
Belfy82
Hi guys,
I am just wondering if anyone with a 70 series can help me with a problem that I have,
I was out on the tracks yesterday and had to reverse back and a stick has ended up tearing the crank sensor wiring out of the plug as well as going straight through the radiator and the turbo air intake pipe, car died instantly and pissed out all of the radiator fluid.
If someone would be able to have a look at the plug on theirs and tell me which wires go where it would be greatly appreciated,
There are three wires on the plug which is located under the car near the crank pulley the wiring loom side of the plug has a brown wire, a white wire and a black wire, the sensor side of the plug has a black wire, a white wire and a red wire, two of the three wires were ripped out so I know that the wiring loom plugs brown wire goes to the sensor plugs black wire which leaves me with,
Wiring loom Plug,
White wire
Black wire
And,
Sensor side of the plug,
White wire
Red wire
If there is someone that can have a look at what wires go where for me that would be a great help, and if anymore info on what I am trying to explain is needed either post me or pm me for my number and I will try to explain it a little better.
Cheers guys.
Shannon
BTFIVO
She's pretty dirty but I think it will get you out of the poo. If you want another pick, let me know.
Belfy82
That's the one mate, cheers for your help being something that's connected to the computer I didn't want to have it backwards for long term use Incase something shorted out, by chance that's the way I had connected them to get me mobile again, it just doesn't look right having the black wire go to the red,
I have insulated the turbo pipe and pulled out the radiator yesterday and melted my tackle box full of sinkers on one of those portable gas stoves poured the melted lead over the hole in the radiator just got back from a 20k drive to the campsite and it has reduced the hole in the the radiator down to a drip so should be good to get into nowra on Tuesday hopefully.
Thanks again you've saved me on this one mate.
Cheers,
Shannon.
BTFIVO
No probs at all mate. I bought an 80watt soldering iron and did a similar repair with silver-solder and it held up well. I totally isolated the leaking tube, folded and crimped it over, then soldered it shut. I guess I lost one cooling tube, but it remained integral for the following 5 years until I sold the vehicle. If you run into any further drama, give me a yell.
