Help with a440f transmission!!
ajjg
Hi everyone, i'm new this comunity and i joined because i have an fj62 auto and i am in the proccess of rebuild the a440f transmission.
What happened is that one of the rear clutch assembly tabs that separate the small springs is broken, i'll leave a picture.
My question is, can i keep rebuilding the transmission? Is it safe enough? Or do i have to replace that part of the rear clutch assembly? I don't want to waste more time and money making a bad choice
Thanks in advance
Toyasaurus
Matt has hit it on the head.
Why bother to take the trans apart then put it back together without fixing/ replacing broken parts.
You have already done a lot of the work, keep going and you should have a good trans that will last for years.
