Help Understanding Tyre Sizes pleaaasssee
Tristan Botha
Hey there 4x4's
I need a bit of advice and help.
I was given 5 rims originally from a Toyota Landcruiser 80s series.
The tyres that fitted them had this on them...
LT 265/75R 16
and then further on it read 120/116Q.
Will these rims and tyres fit my 1997 Holden Rodeo LX 2.8L Turbo Diesel?
Would really like some feed back on this if possible because i cant find anywhere in the manual or on the inside of the car doors where it states what sizes i can have.
Thankyou so much for your help, i really appreciate it as i am stuck in the mud on this one.
P.S. if you can also explain what those markings on the tyres mean that would be great
Split pin
Hey there 4x4's
LT 265/75R 16
LT = light truck.
265 = tyre tread width in millimeters.
75 = height of the tyre from the tread to the bead.
16 = the tyre is for a 16inch rim.
120/116q = speed rating of the tyre.
hope this helps.
Also I donot believe the rims and tyres will suit the rodeo. As the rim offsets are different.
Grumpy
Maybe get in touch with your local wrecker and they may be able to advise u with if they will fit or not, Cheers
frosty
LT = light truck.
hope this helps.
The "75" is actually the height in percentage of the width. Therefore 265 mm wide, 75% is 198 mm high from the rim to the tread. I run 255/85 x 16. 255 wide, 216 high, 16 inch rim.
croozza
yes the rims will fit. but no you cannot use them as the off set is incorrect, you would be fouling on vital steering components.
OGJON
the 80 series cruiser has a zero offset (16x8) , not sure of the rodeo.
I've got stock 80 series rims on my Terracan 0 offset (16x7's)
no fouling or scrubbing also running LT265/75R16 muddies
Terracan's original rims are -22 offset 16x7's
not sure about the Rodeo's but just give them a try
also a 265/75R16 is roughly a 32" tyre in the old measurement
but due to different manufacturers some are closer to 31"s & others are closer to 33"s
