Help - Rust work on my Troopcarrier
Miles00
Looking for opinions on what to do about the rust on my Troopcarrier.
There is spot rust on the chassis. This is not a huge problem yet. I am thinking ill just coat the underside in one of those rust converters which acts as an overcoat as well. Failing that then POR-15 after some Rust conversion.
The body pannel rust is a little more severe...
As you can see its a bit further along.
Suggestions?
typhoeus
clean it up and treat with the rust converter/primer, then fill with fibreglass resin. sand and paint, its good for 10 years
Rust never sleeps they say.
The surface rust isn’t really a problem, most 4wds have this if used as they generally are.
The body rust, well doing it right is very cost / time inhibitive, you can do it with a good grind / sand, knock it in, fibreglass reinforced filler, sand just under flat, light coat of regular body filler, then the paint preps, rust proofing with tectyl / fish oil mix before getting it wet, then a good 2 pack paint.
Lots of labour but you might enjoy the process and satisfaction from doing a bit of a tidy up.
Bomber2012
Can get very expensive and time consuming , I recently had the same dilemma with a 60 series , after weighing it up I sold it .
