Hi chatty, as above if you cut them in half you wont be happy, two piece rods are a lot stiffer through the middle to support the join, if you cut a one piece and put a joiner in it would probably snap once under load unless reinforced which would take away the feel.
The feel is why you probably want to keep them, put em on gumtree sell or swap. There are some good bargains out there second hand, most of my rods ive bought for under $20 second hand, they might need a few slight repairs and a coat of rod varnish but has saved me lots $ when a decent surf rod can set you back over $250.
Or you could put rooftop rodholders on the van?
