cokeaddict
Between 70 /80 kms I get this roaring grumbling noise through the drive line.
Having the car up on 4 stands and running in 4wd High at around 80kms it sounds real bad. Noise is still there with or without wheels on or off the car.
4th gear the sound is there at around 80kms speed mark.
In 5th gear the noise comes in around the 70km mark (so lower revs) Not as loud as 4th gear but still telling you its there.
get under the car and try to find the source seemed easy as it was really loud at the rear of the transfer case Just before the drum brake. So assumed it was the bearing in the transfer case.
Had the transfer case replaced but noise was still there. 3 people (me included) were convinced that it was the back of the transfer case so I told the shop to replace it. Sadly though nothing changed. Thats 400 bucks gone :- (Not the workshops fault as it fooled us all)
Get the car back home and Back up on 4 stands and did another "process of elimination" run. The stands used were sitting on the diffs and they are 6 ton each industrial stands. no cheap thrills here.
1st run: 2wd...NO NOISE
2nd run: 4wd high, around 80kms noise is "felt" and heard through the car.
3rd run: 4wd low range, still there but no where near as loud I think this was mainly due to the fact that it was friggen hard to get up to 80kms in low range
4th run: removed front tailshaft, no noise in both high and low range
5th run: removed rear tailshaft, ( both F&R shafts off) run at 80kms no noise in both high and low range
6th run: fit front tailshaft on and at 80kms noise is back BUT now sounds like the front diff. The noise itself is strong and loud near the front diff flange area. Still can be hard at rear of T/F case like originally but now louder at the front diff near flange.
Uni joints are fine and new. I checked them on bench many times. All good here.
So after many checks I pulled the front diff out today and took it to a diff shop here in cranny, Sadly though the guy called me and told me the diff is fine and cannot find anything wrong inside so I gave the order for him to replace the bearings now that its out anyway, not cheap at around 450 bucks damn it. I wont get the diff back until tuesday now due to easter weekend
Any other elimination processes you guys can suggest I check when i get the diff back?
