Davidman
Hi All,
Not sure what the bit I am asking about is called, or even if it should be in the 'Suspension' thread. It runs across the width of the rear of the vehicle and sits just in front of the rear diff.
As they say, a picture tells a thousand words, and I hope someone knows what I am talking about.
This is the bit I am talking about
Another view of the same bit
There appears to be a lot of movement / free play in this bit. It is easy to slide sideways without any real effort and there is about 50mm play in this direction.
Also, you can push the bar upwards ( away from the ground ) and there is about 30mm play in this direction.
This photo shows how it normally sits
This photo shows some of the vertical free play in the bit. There is more than shown in the pic, it was just difficult to take a pic at the same time as moving the arm up.
I suppose my question is, is this normal. It is on a 1996 NJ LWB 3.5 litre petrol Pajero.
Any help appreciated
Thanks
Thanks
