August 2000 the chassis changed from the Titon to the Pajero. Means it had leaf springs in the back and changed to Coils. The ride would be smoother in a coil rear end. Going from the original suspension to aftermarket make a hung difference in handling and all good. The Challenger over all lift from the sagging suspension was close to 70mm. After bedding every thing down that was more like 60mm. From the standard height, I received 40mm lift. Springs have better load ability over coils but given the choice again, I would go the coils. It is cheaper to get suspension parts as it is a Pajero Gen 2 frame. I notice little change in the ride height when the camper is on the back. Recommend a transmission cooler to be installed. New transmission fluid every 20,000km makes a huge difference against Challengers that haven't had it done. I do it myself and it is easy to do.
