Has anyone fitted 35" tyres onto an IFS 100 Series
Hammy
Hi, have been asked by a Customer to upgrade suspension on his HDJ100 Landcruiser to accomodate 35" tyres, does anyone know what is required to make this size tyre operational?
Hammy
Dunno but am following with interest.:)
After a bit of Googling, I found this bit of info on another forum:
" I am running 35 inch MTZ's (315x75x16) on my IFS 100 series and its great but expensive and a lot of work. Have had to cut out some steel and get the hammer involved heavily, lose the front mudflaps. fit wider off-set rims, a 25mm body lift and wind the torsion bars up for a 55-60mm down-travel. Even with diff drop fitted, I am wearing through steering rack ends every 10-15k which appears to be due to the angle as a result of lifting it. Its good fun though"
So, I think I will try to talk the owner into 33's, and lift the front a little more using 13mm longer EFS XTR Shocks and install a diff drop kit.
The steering rack is still going to cop it though.
Hammy.
80lover96gxl
Hammy.
Cheers for the info Hammy.
Im currently running 33's on my ifs hundy at standard height without the t bars wound up. So far no issues, this includes a fairly large high country trip, flinders trip and a couple of SE SA coast beach run trips and all good so far. Only had the truck 6 mths .
Gavo
Yeah Matty on out high country trip with 285 75 16s on 100 series IFS ate up the tracks. Very capable truck.
Chard
I've seen one with a three inch lift flexing before. The tyre was so far up the guard it was clicking on the sidebitters. That was the rear. Front seemed to have no issues as there was bugger all droop left in the suspension. Just had to cut the knob off the mudflap (as a SAS 105 needs anyway). I could imagine it would be heaps of stress on the rack especially at low pressures and balding tyres. I replaced my steering box twice and pump once running 35's on my 105.
80lover96gxl
My side biters were clicking on my 105 with 33's on the rear, some nice shiny bits on the rear inner guard.
Patrols should come with a Duramax standard. And the Chev/Isuzu powered Patrol should be built and assembled by Toyota! Ide buy that!
Make that 3 please, when can I put in an order, I will have mine with procomp beadlocked 35's, high mount winch, all the bar work, long range tank, blacked out windows and a nice burnt orange paint job to finish it off:cool::D
I would probably re finance the house for that:);)
