I've been chasing a handling problem in my 60 series since purchasing it nearly 12 months ago. While travelling at any speed, it 'bounces' right (maybe 6") at the slightest hint of a bump or uneven piece of road.
I've had two wheel alignments done (1st was a waste of time, scrubbed outside edge of left hand front tyre off within 3 mths) and second guy said that same wheel needed 2* of caster but right hand side was OK.
To cut a long story short, I've fitted new springs, bushes, (correctly according to ARB), shocks and caster wedges (to both sides) trying to fix the problem, but it remains with no real improvement.
The other day I was having a look at the truck and noticed the rear wheels didn't seem to be tracking true with the front. Looking from the back, the front left wheel looks like it sits outside of the left rear but the right front looks to be sitting inside of the right rear. Make sense?
Some very quick measurements showed the left rear wheel to be about 5mm closer to the fixed spring mount than the right hand side.
The front was out by around 3mm.
If that was all too hard to follow, what it means is the right hand side of the truck (from the rear of 35" front tyre to the front of the rear) measures 1834mm, the left measures only 1827mm.
I realise the measurements will be very rough but visibly the wheels don't look 'aligned'. (Yes, diff housings are sitting centred over spring pack bolts, front and rear).
Now, I'd rather not sell it as I feel it will be a great truck when the handling is sorted, but it is starting to get me frustrated, not to mention giving me a sore back from the jolting around, so it has crossed my mind to be done with it and get something else.
I'd be interested in your opinions as to what may have caused the misalignment and any remedies to fix it and/or the handling.
I can see no obvious signs of prior accident repair or damage underneath so it really has me stumped.
Thanks in advance.
Thanks in advance.
