I have had a hand winch for years and have pulled all sorts of things over up and out with it.
But I have never used it to remove my 4x4 from a sticky or hopeless situations.
As for the power that you can exert with a hand winch I could not see without a lot of effort why you couldn't unbog yourself no matter how badly stuck you are.
I have pulled huge trees out of the ground with mine but I have always used one or two snatch blocks when doing so.
It has surprised me more than once the power that can be put through a hand winch.
The biggest tree I have pulled over and out of the ground was a forty foot high gum tree!
We could hear the root system breaking under the ground with the force we exerted using two snatch blocks.
Only once have I broke the shear pin and that was in a single line pull.
Oh and I lied I did when I first purchased the winch skull drag my Toyota up my drive with the hand brake on and in gear as I had the other end attached to my truck.
