Hand winch question
03hilux
Just a thought. Maybe others have thought the same question.
Can a hand winch use dynema rope, or are they purely a wire cable thing?
80lover96gxl
Would think it would be cable only due to the way it clamps the wire cable during the process, think thay would damage to rope to easily.
Sent from my GT-I9505 using Tapatalk 2
03hilux
That's what I was thinking.
What would it take to make one rope compatible, and are there any available on the open market?
dhula
I don't think you could make a tirfor style hand winch work with rope.
Tirfor style hand winches use a clamping system to hold the rope and pull it through the body of the winch.
The analogy I try to use is: using your hands to pull a thing towards you with some rope.
Thing is the clamping force exerted onto the rope by the winch is far greater as it's these clamps that hold the weight so I reckon the winch would damage the rope quickly.
If you used a drum style winch however (like a come-along) then you could use rope as the weight is held by the turns around the drum in a similar fashion to vehicle mounted winches.
I'd happily be proven wrong on the rope in tirfor thinking tho as that would make my hand winch so much lighter and easier to use.
Cavsarge
Rope is a definite no no for this style of winch for all of the reasons mentiond- tried one at work and it didn't end well for the rope!
As mentioned you couldn't use it in a tirfor so you must be talking about a wire rope come along sounds like a good idea it should be possible and save a bit of weight but you would have to make sure it doesn't get pinched when using it and make sure the pulley near the hook is suitable for the rope & the guide near in front of the drum is suitable with no sharp edges. If you were serious about doing it I would buy a very good quality maybe one dual ratchet would be good which has high pulling capacity because the can break fairly easy. One of the many times I got stuck by myself in a shorty 40 I hooked it up tensioned it then drove forward a bit and had to keep repeating this then I slipped backwards jaring it and damaged it that's why I say buy a sturdy well built one which might help.
