I think you may be referring to changing your IP address. If so you would have to contact your ISP, as they are the ones that allocate this number to you. Many of them do not allocate Static IP addresses, but will usually have dynamic IP addresses (i.e. it can be a different IP address every time you connect to your ISP).
If your IP address is dynamic, then just turning off your modem for a few minutes, then turning it back on should give you a new IP address.
I would also suggest getting a good virus scanner and firewall (the standard windows one is not enough) that is constantly on, as this will usually stop this sort of this in before it can cause problems. I personally use Norton 360, but most of the well know security packages will be more than adequate.
