H260 Diff
Big Matt
Ok all whats the deal with the H260 Diff ?
Was it only in the utes ?
Is the extra size worth the extra weight ?
Any info at all ?
Also any idea on standard Diff ratios for a TB4.2 auto ?
Big Matt
Yeah pretty sure there were only in leafs
Just wondering if its worth the stuff about up grading to one over the H233
They were found in wagons as well as leaf sprung utes .
A normal patrol diff as we all know -takes alot of abuse to break one .Everything about the h260 diffs makes the normal patrol diffs look tiny .
Depends on what you plan on doin with your patrol and how much hP you want to have running to the wheels .
Unless its stupid amount of power and a full on race truck I would leave the normal one in .
Would I be right in saying that the H260 diff can be found in the 4.8 Patrol.
Its really just a lottery draw, some 4.8's got them, some zd30's got them, and even some leaf utes got either.
As for there strength, well its argueable? the pinions still snap easily due the fact the outer pinion bearing is the same as the h233, so the big step down in diameter seems to be a weak point. And although the axles are very large, the material and the hardening is average at best, some are very brittle and some just seem to deform badly. We have broken 3 axles and 2 pinions, so are a bit weary of using them any more.
tappets
everything has a breaking point , even aftermarkert 4x4 products said to be more superior than others seem to fail and not live up to expectations .
big horsepower i would still go the h260 diffs and mayeb even the normal h233 to a point
Ruffy
The H260 was found in MK and GQ leaf sprung diesel utes and GU utes and wagons in TD42's, ZD30's, tb45's and tb48's. There is rhymn and reason as to what got 'em but it's not simple.
I would not go to the trouble of fitting a H260 unless you needed a new diff and had one kickin' it fresh in your backyard. There is no major benefit.
The H260 was a 4.1:1 ratio in all Patrol fitments.
The H260 was widely used in nissan and diahatsu commercials and had 4.88 and 5.24 gears.
4.3 are really common, then 4.6 and 4.1 about the same. Later model h260's are usually 4.1. In the past 2 years we have bought 2 GU, 1 GQ and 2 MQ centers and various axles, but am really sick of breaking them, so going back to toyota stuff as the axles seem to take more torque :mad: and the centers are just as strong without the weight penalty. :eek:
Jarh73
:) More than happy to stand corrected and learn more info... Personally i've never come across a 4.3 or 4.6 in a Patrol. Have seen a 4.6 in a daihatsu though...
Thanks Mad.
ALL 2.8 liter GU's have 4.6 diff gears. And AFAIK the GQ 2.8 also has 4.6 diff gears.
Justin
Black Bull
The Axles are a lot bigger/stronger The early MK/MQ ones and a few in the GQ's had 35 spline axles the later 37 spline vs the H233's 31 spline.
They have a bigger Crown wheel but unfortunately the pinion is the same size and is the weak point on them if you push the limits with big horsepower and tyres.
personally I don't think there's any advantage to the H260, it's bigger pumpkin and lower ground clearance and massive weight is more than a trade off for the extra strength.
