GU Patrol Rims
shinysideUP
Has anyone got a set of GU Patrol rims they want to get rid of. Early model type (Steel Rims) for my '99 Model Patrol. Want to use them as a spare set to put Muddies on.
Thanks
Traveller
Give Patrol-a-part a ring. They are in Bates Close Pakenham. Rims were $85 a pop a month or so ago.
Would stick the number up but dunno where I put his card. Let him know you heard about him from this site too. bit of pr doesn't hurt!
Jok
shinysideUP
Jok
Thanks, I'll give'em a go.
croozza
didn't the early model have problems with cracking rims, would be better offf with aftermarket steel rims, cheaper too.
8UFF35T
No they didn't, no such thing unless you abuse the shit out of it.
I reccomend 80 series landcruiser rims, its much stronger, plus better offset and a hell a lot cheaper.
If you can't find any PM me your state and postcode and i'll find you some.
shinysideUP
Can a Toyota 80 series landcruiser rim fit a Patrol? If so would they be cheaper than $85 per rim which a previous post has indicated.
8UFF35T
Yes they can fit patrols, and yes they are cheaper than $85. Last time I bought a set they were around $45ea. Have a look around there must be a few in boostcrusing, 4wdA, landcruiser forums etc.
Good luck,
shinysideUP
Good luck,
Thanks for your helpful comments... will look in to it.
croozza
I'm sorry but I do believe you are incorrect in saying that, I have got quite a few mates that bought brand new GU patrols (the early ones) and all of them had cracked rims, none of them took them off road as they still had their old patrols to play with. This is why Nissan changed the style of the steel rim later on.
Traveller
Seems to be a bit of 'shouting' going on for no good reason here:rolleyes:
This is the sort of stuff that causes blues, play nice you lot:eek:
As for cracked rims, yes, Nissan recognised the fault and replaced some sets-dunno how
many. Have a cracked one sitting in my shed now.
Jok
Maniac
just read all the posts, I totally agree with croozza, Nissan changed the rims when they acknowledged the problem, since then they went to alloy wheels.
