Decide it was finally time to build a comprehensive power panel for my GU.
First step was trying to figure out what was behind the rear panel on left hand cargo area. With the aid of some helpful forum members and a camera snake there appeared to be nothing behind the panel.
So out with the dremel for the first cut just to make sure.
So far so good now time to cut the rest out.
As you can see there is heaps of room.
Next stage was to trial fit the prototype panel. I had some spare 5mm grey PVC sheet that I will be using to get everything lined up right and to see how to fit everything. I have done a drawing but you never know until you start. I'll put up a detailed drawing once all the measurements are finalised.
Prototype panel with merit plugs, ciggy plugs and switches.
The plastic interior panel is strong enough for Riv Nuts so once I have finalized everything I'll hold it in with about 6 Riv Nuts.
The final panel will have:
2 x Merit Plugs
2 x Ciggarete All items will be individually switched and fused.
Twin outlet 240 volt GPO.
USB charging outlet.
Volt Meter.
Amp Meter. (not 100% sure about that yet)
Fuse block with automotive fuses.
Stay tuned more to come.
Justin
2 x Merit Plugs
Volt Meter.
Justin
