Grrr! Fuel in my oil - Paj NS
Your view on how I should approach this
  • DIY (please add comments on approach)
    Votes: 2 15.4%
  • Get it straight to a garage
    Votes: 5 38.5%
  • Give up and buy a beach buggy
    Votes: 6 46.2%
  • Total voters
    13
sandgroper2
My Paj has just passed it's 5 year warranty :eek: and I sent an oil sample off for testing. It has come back with an 'action' recommendation. I have a reading of over 1 for fuel (% by volume I think). The maintenance recommendation is to check for source of fuel leak.:(
I wouldn't know where to begin should I just bite the bullet and get it over to the garage.
Reddave
Petrol or diesel? Turbo?
How many kms has the engine done?
Is it actually using more fuel than this time last year?
"Some" fuel will make it past the rings into the sump via normal combustion, but shouldnt be a huge amount.
Is the company you used reputable?
Are you sure they havent fudged the results? (not suggesting that they are, but some places make money off using free or "low cost" tests/samples just to get you in the door)
sandgroper2
Hi Reddave
In answer to your questions. The car is a 3.2l diesel, it has done around 3000km on this oil with nearly 110k in total. I hate to admit it but the wife has been using it a lot recently after totalling her corolla for school and shopping runs - this may have a lot to do with the problem.
With regard to the oil tests I am pretty sure they are genuine as I have had clean reports from this outfit (roktex) before. While they have a $29 special on at the moment it is for the full report so I don't see any issue there - the main reason I use them is that they supply a basic sampling kit (meaning I don't have to buy a pump) and the kit includes a postage paid mailing pouch to the lab.
I accept your comment about there always being some fuel in the oil but unfortunately mine is coming in as significantly higher than usual.
Reddave
No worries mate, I never said that the company was out trying to make money!!!
The reason I asked about the fuel economy was, is the engine using marginally more fuel than normal?
I would start by getting the fault codes and live data in the ECU checked, speak to a diesel specialist and they should be able to have a look and tell you the condition of the internals of the engine via a compression test. Most automotive workshops don't have the tools to compression test a diesel.
Tatty
Compression test is a must. You could buy the kit yourself, or attempt to find someone/workshop to borrow it from, but probably taking it to a workshop is the easiest thing, as you have to take off the injector and have the right threaded fitting etc.
Is your wife a good driver? Genuine question, as she could be overfuelling the car a lot and it's leaving the engine no option but to let the fuel go past the cylinders into the sump. Swapping from a petrol to diesel is a big change.
Have you dropped the oil? Maybe do an oil swap, you could have a bad batch or something went wrong in the servicing. Check your oil and see what it's like.
Hiya Tatty
This is a strange comment to me,How can one over fill a tank....?????? I thought you go fill up the tank and when the nozzle at the servo goes click thats it....
profoto
I had a compression test done by an outfit who simply rotated the crank and measured the resistance, they said it was as accurate as pressure testing (compression) each cylinder but was just a lot faster.
It came back as all clear and was wrong as several valves were burnt (80 series on gas, common problem).
I hadn't heard of this before and don't know if it's still used but it is clearly not accurate.
Swaggie, overfuelling not over filling, my interpretation of that is hammering the beast, I find my turbo responds best to gentle gradual pressure rather than slamming my foot on the loud pedal.
monjesa
Where did you get your oil test done, are they independent of manufacturers and major garages?
Hi Reddave
sandgroper2
Given that the wife totalled the corolla and despite protestations to the contrary I would not describe her as a good driver - heaven help me if she ever joins this forum!
Tatty
Hiya Tatty
Hey Swaggie. Overfuelling is when driving a diesel car, you basically plant the foot and it puts too much fuel in the cylinders so you get black/grey smoke out the back. I was only testing a theory, though.
Haha, well, consider it an option, then. But I'd still drop the oil and have a look for yourself.
That's an inaccurate way of measuring. Half the time a crank might have two cylinders at TDC, or LDC, let alone the extras that cause resistance. The only accurate measurement is a proper compression test.
Also, if your's was gas, why couldn't they just do a compression test? It's easy as piss on petrol motors, you can buy kits for 20$ and do it.
profoto
I am not a mechanic but will perform some menial tasks, the cruiser was backfiring and I took it off to get tested by 'experts'.
I did learn something from this, not all repairers are competent as a second opinion revealed that all was not well and they said they could also hear 'chuffing' from the exhaust which indicated to them that valves were buggered.
Outfit 2 did a proper pressure test but I am pointing out that whilst not gullible I am not aware of every little device that is used in the workshop.
croozza
From my understanding, Fuel will always be present in oil that has done over 1000ks, the reason being is, unburnt fuel mixes with oil during the combustion process, this oil then returns to the sump taking the unburnt fuel with it, and over time accumulates. Depending on how many ks you did with the same oil in the motor at the time of testing, will determine the % of fuel in the oil. It is like saying, I have done over 10000ks and the oil level is still reading full, but in reality, how much of that is unburnt fuel. It does not matter if it is Petrol or Diesel, they both will do this. It does not mean the motor is on its way out either.
prawns
That would be called "blow by"? (where the rings dont seal enough to prevent fuel mixing with oil)
My last motorbike (r6) cracked the nicklesil plating in the bore and had a chronic case of blowby before I sold it as a rolling chassis lols
Bit more info here FAQ: What is “Blow-By� or is it normal for my car to have oil in the intake plumbing?
As mentioned - you never achieve a perfect seal but you can ask for a "leak down" or compression test on each cylinder to see if any are below spec at your local mechanics (its the first thing I would be doing if your worried)
croozza
Blowby is different, it is caused by force, the problem mentioned earlier is normal for any engine, it is just unburnt fuel mixing in with the oil. This is why oil loses its viscosity, because it is being mixed with unburnt fuel. Thats one of the reasons you do oil changes.
prawns
If the fuel/oil isnt mixing through the piston rings (which is called blowby....?) how are they mixing at all?
The blowby I personally had wasnt caused by force but due to cracked nicklesil plating in my bore allowing fuel seepage into the sump (which I supposed technically was forced down with every piston fire but it also leaked down overnight with no pressure)
Edit:lol ignore this post - I reread your post and it makes more sense to me now lol
Tatty
Somewhat. This is what I was explaining earlier, as his wife may have a bad habit of over fuelling if she's used to driving a petrol car.
However, anything above, say, a 1% mark, is too much. A little is normal, as the fuel will get through the side walls and into the oil, or through the tappets/lifters, especially as an engine gets older and more worn.
I just have a problem with saying that our oil level reading will be affected by unburnt fuel. It shouldn't be.
