Hi All
As a newbie, there are a few questions I'd like to check out with the collective brains of 4x4 earth to check if I've got my head around things correctly.
Like everyone here, I'm guessing, I'd like to get the most out of my 4x4 (Hilux 2010 Diesel Double-cab) and would love to take a trip into the Outback and do some touring. I'm pretty much sold on the benefits of diff lockers, having seen where they are indispensable. However, I'm still not quite certain about the basics of improving ground clearance via suspension lifts, body lifts & wheel/tyre combination changes. That's where I'm hoping you good people can put me straight!
So, if I understand correctly (which isn't necessarily the case...), the only way to increase ground clearance for the diffs/wheel hubs/control arms etc is to increase the diameter of the rolling wheel/tyre combination. Now, I love the aesthetics of some chunky tyres as much as the next bloke, but I'm guessing that you can only take this principle so far before the tyres are rubbing inside the arches under suspension compression. Obviously this rubbing issue would be compounded by turning the wheels or fitting wider tyres.
So, my first question is what are the options for counteracting this? If I've got my head around this, then fitting spacers to the suspension mounts would lift the body. So, if your wheel/tyre combination diameter increases by 2", then a 1" spacer (ie. the rolling radius change) would give you back your original wheel travel. It would just need careful attention to tyre width under compression & wheel turning to avoid any fouling. Is this thinking correct, or am I missing something? (I realise the effect this has on gearing).
You could also raise the body by fitting longer suspension instead of spacers. But, correct me if I'm wrong, this only increases the ground clearance of anything attached to the bodywork. So, this would have no effect on the clearance height of the diffs, for example, but would take the oil sump farther out of harms way.
I'm struggling to visualise if there are other benefits of longer suspension. Does longer suspension give increased travel too? I could imagine this allowing the wheel to drop further into a rut, but does it also allow a greater travel over bumps too, or do you just hit the bump stops when the original suspension travel is used up? For some reason I'm having trouble getting my head around this bit!
I suppose, ultimately I'm asking for advice on what the benefits of a suspension based lift, versus a body lift plus wheel/tyre diameter change are? Presumably, the standard factory alignments are maintained with the wheel/tyre change, plus the body lift option? Whereas, I understand that CV joints have to travel through greater angles with suspension based lifts, necessitating drops kits to be used (over 2"). Are there any other pros/cons to these two different options?
As you'll gather, I'm having fun getting my head around these ideas. All pearls of wisdom gratefully received. Or if this has already been covered elsewhere, please direct me there.
Hugh
Hugh
