I have done a bit of experimenting with star pickets. One evening in the Big Desert when I had a bit of spare time I kocked about 4 star pickets down into the sand in a straight line, about 1.5 metres away from each other. They were about 1 metre in length. They went right down their full length. I had drilled out a 3/8th inch hole at the top of each dropper and fitted a high tensile 3 or 4 inch bolt to make a T at the top of the dropper. Theese bolts allowed me to use three 8mm ropes to tie the tops together. Each sropper being supported by the dropper behind, as the stress from the winch is being used to pull the vehicle.
If I did it again I reckon three lengths of chain would be stronger for that job.
I did not have winch, Instead I used my high lift jack as a hand winch. I had to purchase about4 metres of heavy duty chain and a shorter length also, and various bolts and D shackles to make it all work. (I have since bought a 1000kg block and tackle. I found the high lift jack method was just too slow and cumbersome. Have not tested the block and tackle as yet.)
I set the SWB Patrol up on a slight uphill incline, on soft, deep sand on the side of a creek bed. I put the hand brake on. Can't remember now, but I might have engaged the front hubs and left it in top gear too?
Anyway it all seemed to work. I dragged the car about four metres through the sand. I think one of the star droppers, probably the one furthest from the car, developed a small bend near the top, since it did not have a dropper behind it to even out the forces.
I also did some experiments in sand less deep, at Port Gawler, north of Adelaide, where the droppers only wnet down 50cm or so. This time I angled them backwards from the car a bit. I used my ropes to set up sloping braces, from the top of the dropper closer to the car down to grouind level of the dropper behind which was bracing the first one. I think i set up a sort of V shape with the droppers that time - one dropper at the front, two behind it for support and then another one behind each of those. So 5 droppers all together.
This set up also worked quite well as a ground anchor.
I did a report on this forum and some-one posted back that this star dropper method is actually used by the Australian Army! Looks like I re-nvented the wheel lol!
Will see if I can find a link to that thread froma few years ago.
