Grinding kind of noise when pick up
dom14
Grinding kind of noise when take off
I have a GQ Patrol 20+years old. 300k on clock. Manual and carby on RB30 motor. The car makes a slight grinding noise when taking off. If it's up the hill take off, the grinding noise is stronger, if I'm taking a bend, the grinding noise is higher as well. If it's flat ground or down the hill take off, less or no noise. Only on first gear(or second gear some times) when picking up.
It's been there for last three years or so.
Do I need to worry about it if I'm going on long trips?
Where is the noise coming from?!
Any help would be great!
Thanks
P.S. I feel the noise is more from front of the car than rear end. I can feel the grinding, just under me. Not sure if that makes any sense.
80lover96gxl
Sounds like it could be gear box related, im no mechenic tho.
Had a paj quite a few yrs ago that did a similar thing, cant remember what it was but think had something ro so with 1st gear, was a long time ago so not 100% sure.
dom14
Yes mate. I've heard that too. And that's my worry too. If that's the case, I would need to get the box reconditioned asap. Heavy job though. I may be able to swap for a second hand gearbox?!
I better get into immediately.
Thanks
Grumpy
Sounds a bit like it could be related to the clutch or thrust bearing maybe provided it is a manual, your details are not specific enough to think otherwise.
if it was a thrust bearing I would imagine it to be there more constant .
Is it more of a creaking sound maybe than a grinding sound ?
Also its higher when taking a bend makes me think other than a gearbox as if it was gearbox related it would be more constant and would be noticeable on take off regardless of uphill down hill or sideways .
The nosie just under you is that as in feel it up thru the floor just under your feet . if this is the case certaintly not a thrust bearing . As a thrust bearing will be more of a rotaing grinding /high pithced squeal that can not be ignored even by cranking up the radio and wouldnt have lasted 3yrs as you mentioned .
I may be wrong and stand corrected if so , but from your description it may be body bush rubbers and control arm bushes ( chasis end ) .
As when taking a bend load transfers thru the body if the body bushes are stuuffed they will compress and metal to metal contact will occur between the body and the steel spacer tube inside the body bush rubber . Creating a grinding /creaking sound . Also on take off up hill as you move off load transfer back thru the entire car .if control arm bushes worn a grinding /creaking noise will be felt and heard from the entire front end movment thru the worn bushs . if you have evr seen the rear end of a patrol or crusier with buggered rear trailign arm bushes or leaf springs with flogged out bushes being tested stationary in a workshop you will see exactly what I mean . A worn out gearbox mount will also make all sorts of odd noises as the g/box is no longer mounted .Maye even be a wheel bearing as a worn bearing will be more so heard when
cornering .
As i said may be wrong and stand corrected if so . This is going by what you have described happens when the noise occurs . hope this makes some sense for you dom
prawns
Crikey seems the month for repairs
Ive had a few issues in the past years back with caryard cars which sounded like they had issues in the front end, but it turned out to be the back end, or sounded like the left side, ended up being a issue with the right side once the mechanic had a look.
Sometimes sound can travel in wierd ways down the chassis and things, and make it sound like the noise is coming from a completely different spot once your sitting in the drivers seat
maybe somthing to keep in mind incase somthing like this is happening to you - maybe dont discount anything without checking first (or asking on here like you did, great place for nutting out issues this forum :) - Theres no point me offering advice though really to be honest Im a mechanical idiot but maybe somthing to keep inmind
dom14
cornering .
Hi mate,
Control arm bushes and perhaps few other bushes(i can't recall as it was done around 2 years ago) were done. The noise is coming more from the middle of the car,just behind me. It's more of a deep, slightly low pitched grumble than grinding i reckon. 'cos I'm familiar with brake grinding kind of noises. It tend to do it when more power is demanded for take of, like when up the hill or taking a bend while take off, on low revs on first gear.
I think it's time for me to post couple of pictures underneath, showing the bushes and control arms condition. I'll do that tomorrow.
I wasn't able to test whether it's doing it under 4WD or not. 'cos I had different size(larger) wheels on back and almost stuffed it up today by trying to drive on 4WD. I think I couldn't get the hubs to unlock(manual hub though) or disengage the 4WD until I found, backing up the car was the way to do it. Scared the shite out of me, as I thought I stuffed it up. Poor concentration from my part I guess, not thinking it's bad to drive on 4WD with different size wheels.
I will put all same size wheels tomorrow and do the test properly.
Thanks mate.
dom14
Nope mate. What you said make perfect sense. I had similar experience with cars in the past. The noises come from under the chassis can be tricky.
dom14
Update!!!
Hi Guys!,
I did few test drives today with the 4WD on and 2WD. For few days, I've put slightly bigger tyres on back wheels. I've put the all tyres the same now.
I was not able to reproduce the grunting noise today at all.
And my apologies to you all, what I haven't mentioned was this noise was not there all the time, in the past. Some days it makes it, some days it doesn't.
Sometime, for whatever the weird reason, it's not there. Today was like that.
Either 4Wd or 2WD, I couldn't get it to grunt.
Any advice please!
Should I simply ignore this?!
Thank you
prawns
just at a stretch and because you mention you had bigger tyres with the noise and now its stopped with smaller tyres at the moment.....
Maybe check your big tyres for rub marks? - perhaps they are hitting the body somehow when the cars rear drops from acceleration in 1st/2nd (good acceleration) and uphills (more weight over the bigger back tyres) like u mention? just seems to fit into the symptoms perhaps.
Had a mate with a old cortina with the wrong offsets - he used to scrub his guards slightly over speedbumps - was a bit of a wierd noise might fit (easy to check anyway bit of a longshot I guess tho)
Alby123
Regarding the noise on take off, have you given your vehicle a 2" or more lift. If you or the previous owner have given it a 2' or more lift, then you need to check the alignment of the rear diff. All you do is to measure the distance from the chassis rail to the outside wall of the tyre, then go to the opposite side and measure the distance from the chassis rail to the outside wall of the tyre. It is very important to try and measure each side using the same point of reference. If there is a difference in the results you will need to install an adjustable pan hard arm to re-centralize the diff so that it is perpendicular to the tail shaft.
The other thing to check is the alignment of the angle of the diff to the tail shaft, what this means is it should be a straight line from the tail shaft to the diff. If this is not the case then you will need to install adjustable upper trailing arms.
dom14
Noise was there already. I got couple of bigger tyres for free and put them on rear for couple of weeks as it kinda look good. But, the noise is unrelated.
Only thing I could connect the noise to the rear end is that there's a slow oil leak from left axle oil seal. Oil slowly leaks into the bearings and come out the bearing seals and leaks into the brakes, but very slow leak. Diff is not low in oil.
I know the noises can be tricky. but, I feel like it's coming more from the front end, but I can be wrong.
The trickier part is that it's doesn't happen all the time.
Thanks mate
dom14
Hi mate,
Mine definitely has a lift. How do I know whether it's 2" or 4"?
Is there a way to measure it?
Without measuring, by the looks of it, the distance from the chassis rail to the wall of the tyre doesn't look the same in both sides. I also have slow oil leak from left rear axle oil seal(even after replacing the seal twice). Mechanic ordered a harder oil seal than the softer ones. He asked me to install that and the oil leaks should stop. I'm not sure whether this is related.
I think you pointed out a very likely issue with my GQ. I need to look into this straighaway.
It never crossed my mind, suspension lifts in the back can send the diff out of alignment.
I have 222/75 R16 ATs at the moment. Does it make any better if I put larger(higher diameter) tyres for above issues with diff mis-alignment?!
Or do I still need to install above adjustable gear to fix the problem?
Can this issue affect the front diff the same way?!
Thanks mate.
Alby123
When you do a 2" lift or more, or increase the tyre size you need to measure each side of the vehicle. Measuring from the exposed outside of the chassis to the outside wall of the tyre. When you go and measure the opposite side make sure that you use the same points to measure from when you measured the first side.
If the rear diff is central in relation to the overall width of the vehicle then the diff is in the correct position; however should there be a difference between each side then you will need to install an adjustable panhard arm to realign the diff back to it's central location.
Regarding the angle that the diff is in relation to the drive shaft, where the universal is on the diff it should be a straight line from the drive shaft. Increasing the diameter of the tyre will have some effect on this. How much depends on the vehicle and how much the tyre diameter was increased. If it is noticeable or you find by measuring the angle of the driveshaft and where it is bolted to the diff ; then you will need to install upper adjustable trailing arms to correct this.
The Nissan GQ Patrol when it was sold new would have been fitted with 7.50 x 16 tyres and more than likely split rims. This information is stated in the original hand book the came with my 1992 GQ Patrol Wagon.
If you do need to make these adjustments then I would suggest that you replace all relevant universal joints as these would have increased wear depending upon how far they out of alignment .
dom14
I have uploaded the photos of the diff showing tilted upwards which is obvious, and the distance between edge of the tyre and the chassis rail, both sides. Distance is 8cm on rear left side and 9cm on rear right side.
Is the tilting of the diff caused by the suspension lift or is it normal?!
I would appreciate a reply from a fellow who knows a fair bit about suspension lifts in this forum.
Thanks
dom14
Hi Guys,
Please have a look at the photos. These photos give a better picture about the car's wheels and suspension.
Can you guys please tell me how many inches of lift this look like to have?
Thanks
Alby123
Hi I take it the tyres on your gq in these photos are 15". It would appear that you have heavy duty springs given the height that it is sitting at, it looks as though it has castor correction bushes fitted to the front panhard arms. If your gq had a higher lift than 2" you would notice it the drive-ability of the vehicle and the wear on the front tyres would indicate you had steering geometry problems. So I would suggest adjustable panhard arm and adjustable upper rear trailing arms installed. You can do this job with a basic set of tools.
Cheers Alby
muc the truck
Thanks
i hope thats not original Q.A. paint marks on that universal because if it is buy a lotto ticket.
dom14
Hi Muc,
I couldn't quite understand what you meant mate. Are you saying the uni's are being tampered with? That would be me, but can't remember marking them though. I might have, to align it with the diff exactly the way it was. I removed the drive shafts 'cos it was so hard to clean and grease them under the car. It was covered with hard soil, which I think after previous owner's off road adventures.
I took it off to do a good cleaning job before I grease them. I think I did a good job.
I put it back exactly the way it was and torqued the bolts all equally as well.
There was no grease nipple on that back uni though. Is that normal?!
dom14
Hi Alby,
They are 16 inch ones. Only one of the photo has 15 inch ones at the back, so I marked them as well.
Thanks mate
