Grinding gears 2009 gu manual
mills63
Ok Guys.
I have noticed the gears grinding in my 2009 GU 3.0 manual.
It is not real bad but it is in all gears.
I can slow the revs down and it changes better. It seems to get better when it warms up.
My thoughts
  1. I changed the oil it was due any way 120,000 and added some Nulon G70 in the box. There was very few metal flakes in the old oil and almost nothing on the drain plug
  2. I recently had the transfer case replaced and wondered if the gear shift selector or similar could have been damaged or bent.
Any suggestions
Thanks
Steve
GUnka
Take it back to them Steve. Thoughts are if it changes better when matching revs or slower speeds your clutch may need adjusting as doubt it would have been a syncro issue as that probably would have shown up as metal in the oil but not on the drain plug as they wouldn't be magnetic. Check fluid, replace and bleed your hydraulic clutch system too if it hasn't been done for a while.
mills63
Yeah will but probably after the trip. Its not that bad just annoying.
changed the oil and a few shiny bit but not many.
yeah thought clutch my self have a bit of play in the pedal before the cluch engages.
Do you know how to adjust the cluch.
Not sure when the fluid got changed last so that might be a good idea.
Thanks
Steve
abw
Don't have a manual:D But I seem to remember reading on one of the Patrol forums the oil to use is VMX80 (Castrol?).
GUnka
Thanks
Steve
Haven't had to adjust mine but imagine it's not that hard a job. Ideally brake and clutch fluids should be changed around every 2 years but is not the end of the world. Brake and clutch fluid is hydroscopic so it does absorb moisture making it less effective. Not such a big deal with the clutch but more with brakes as it lowers the boiling point and if gets hot enough with introduce air bubbles into the braking system leaving you with at best a spongy pedal, at worst no brakes.
Best bet and something that shouldn't take to long is bleed/flush the clutch lines and cylinders with new fluid then adjust the clutch. If that doesn't fix the problem your clutch may be on it's way out but wouldn't think so with only 120k on it.
mills63
I did the brake fluid about 5000km ago. But havent even thought about the clutch fluid. Got a few days after xmas so might do it yhen.
Steve
