OK but what ratio of Coolant to water in each case?moved to the red
a guy I knew who worked alot with the 1kz and 2lt engine found a lot of corrsion in the motors runninbg green coolant but not in the red.
Thanks for that I might do the same well I'm at itmoved to the red
That is correct, however I think you will find that some (not all but some) are coloured to make different types easily identifiable. This does not mean however that all coolant manufacturers are playing by the rules so you need to check compatibility.Colour of coolant means nothing. Let me repeat that, colour of coolant means nothing.
The ingredients of the coolant is what is important for your engine.
Different colours mean different ingredients in different countries.
Just because your vehicle made in Thailand (for example) came with green coolant, doesn’t mean you replace it with green coolant. The correct Aussie coolant for your vehicle may in fact be red.
Consult your vehicle’s manual and choose a coolant which matches the manufacturer’s ingredient recommendation.
you do realize unless your car will last another 25 years and do another 1,000,000,000 km it makes no difference what water you put in it, coolant mixture and type is vital.As above, use the correct coolant for your vehicle regardless of colour and FLUSH ALL the old coolant out when you change it.
I pull the thermostat out after I drain the radiator then re fill it with demineralised water, start it, run it for a few minutes, shut it down and drain it again, then repeat until the water comes out clear. Then I refill the radiator with a slightly strong mix of coolant and demineralised water to account for the water that doesn’t drain from the block. Then I usually put a little more in when I realise I’ve forgotten to put the thermostat back in lol.
I’ve been told by the local radiator bloke and a coupe of mates who are mechanics not to use nulon coolant, not because it’s no good, but because it’s doesn’t mix well with others. Not that you should mix any, but it in particular doesn’t play nicely.
Sometimes you argue just for the sake of arguing.Oh hang on color means everything, use the correct chemical make up and that will determine color
annnnnd .... there is no ''might'' ... it ''will'' last 15 yearsGo the red cordial it’s makes you more hypo ...
