gq patrol getting hot ...
assasin
hi all have a rb30 gq patrol just started getting hot after being in mud
suspecting fan clutch due to mud and water ?
also my overflow bottle is damaged could this be the cause ?
thanks for your help
not over heating but getting up to half normally sits at quater
if there is a botch up job on the clutch fan to make it constantly fun please share
1nertia
Definitely give it a damn good hose off, careful to cover your ignition system though. My GQ always starts acting up after it goes mudding.
assasin
yea mine doesnt usualy like going near puddles a slight splash and shed run like a dog i got some good water disperant in a spray can from a 4wd store around $20 a can gave the leads a good coat along with the distrbuter cap and coil and that has worked amazingly i suggest anyone suffering same problem to get it i also cabled tied around the leads on the distributer cap for extra protection
as for the geting hot yea it was just mud in the fins the whole thing was blocked up good and proper easy enough to remove so i took it out and hosed it good also while i had it out i changed the thermostat checked all hose tightend belts and all hose clamps i put a new radiator overflow bottle aswell
firstly a cheap nockoff from ebay $20 $9 shipping waited a week for it to arrive from withn 25km when it arrived it was damaged anyway
went to bursons paid $50 orderd and arrived by 12 the next day much higher standard and now no more getting hot tho i suspect it was just the mud in the fins which i checked last
belm belm
haha owell win some learn some
1nertia
Bit expensive for some WD40!, Bit of silicone around the bottom of the dizi is a great help. Also if going through deep water, shorten the air intake, have it suck in from the air box. I went through some deep water, still had the air intake above the water level by a lot, but ended up getting water in the intake from the tires kicking it up. The engine was bone dry though.
Outrage
Snorkel
@Assasin - I've had similar issues in the past, had radiator flushed external and internal. Thermostat, rad cap and fan clutch were all fine. 80% solved heating issue, on a hard working long climb it would still rise a bit more than usual, the last 20% turned out to be dusty air filter, engine couldn't get enough fresh air to stay cool. Just saying to keep that in mind, sometimes it's a few things added up together.
Only had a water issue once after a deep river crossing, sprayed some inox around the distributor cap and went back to normal, next crossing (same one the other way) no dramas.
assasin
hi 1nertia i tired wd40 and it did not help the stuff i got from 4x4 shop is in a 400g can green white blue , by lanotec its called lanolin its quite sticky stuff and have no problem paying $20 for a can off it it goes quite far ive given everything a good covering twice and still have over half a can cant complain at all,
hi Outrage yea thats really what the problem was i had this plus that all solved now
the next thing i have to pay for is the clutch fork boot at $45 argh dam it i recently done the bearing and clutch and found that becouse of the perished boot it wont be long till il be doing the job again unless i replace the little rubber boot
cheers all
