gq patrol extra cab
bally
Banned
gq extra cab
Good Points
gq extra cab chop
Bad Points
What mods have you done?
gq extra cab chop done by radius fabrication, resprayed body black, tray shortened to chasis length, 3" dobinsons coils, efs elite shocks, dropped radius arms, superior panhards, draglink and tie rod, sliders, bead locked 35s
have ordered the following and as we speak its in transit: raslarr tube bar with headlight hoops, td05 16g, radius fabrication manifold, 3 core copper brass radiator, vdo water temp, boost and egt gauge, all new bushes for suspension and steering, new dobinsons remote res shocks, suspension stuff coils, new 35s
Why did you buy this vehicle?
one off custom chop, sure there a plenty of other extra cab utes out there but none with these exact measurements and tray and this makes it my one of a kind toy
How often do you go offroad?
more then i should
tow rig for this tow once its caged and raced
BOUNCY HJ61
Congratulations Bally,
When's Rego? Any Last Loose Ends?
Mate, She Looks Fun Standing Still!
Waiting For The Track Photo's, Ha Ha Ha.
Cheers Michael
bally
Banned
i want to do a little bit of work to the interior. it got a full new head lining and side linings but wasnt really finished off around the rear side window with anything. so its a little weird looking. thinking an upholstery place should be able to stitch it closed or something along those lines. other then thats its going to be a fun few weeks of bolting stuff on and tuning. hopefully will have it turbod and towards being done in the next 4 weeks
bally
Banned
havnt got one yet... iv thought of a few names for when it gets raced... so far im set on "zippy tie aye" (rip off of "yippy kie aye mutha ****a" from die hard movies) other then that there has been a few others thrown around that havnt stuck as much as this :)
bally
Banned
just a few more goodies ;) will also be ordering a safari tuff clutch to go in at the same time as turbo gets done
bally
Banned
my current plan is a little like this:
fix thermostat housings
install new 3 core copper brass radiator and hoses
fit the new bushes and rod ends for every suspension and steering component
install all gauges
install winch bar
service/fix winch and put it in
fit turbo and clutch
decide which lights i want then install them as well as rear work light
put in the new shocks and coils
fit new headunit and wire the amp up so its running two speakers and the sub
fit fire extinguisher to backside of center console
make second battery tray and weld it to the bottom of the tray on drivers side (cutout for spare is on passenger side)
now the fun bit ;)
i want to make a removable rooftop tent frame for the tray... idea is to bend up another bit of tube the same as the head board and weld plate to the base of it so i can bolt that to the rear of the tray. then there will be two rails the same width as the rooftop tent that run to the main tray hoop behind the cab. now, to get these two rails to attach im going to weld 2 tabs off the back of the main hoop that the frame rails can bolt too..... will also make up a set of legs that can be bolted to the frame so i can remove the whole thing from the tray while camping, place it on the ground then have full use of the ute again.
then there is also the idea of rear mounting the lowmount winch and having a highmount up front ;)
bally
Banned
was a bit naughty yesteday and bought some more stuff hehehehe :D:D (i got a little bit of an angry look from the girlfriend when i told her, but i made dinner last night so that took some heat off hahaha)
15x10 allied alloys polished with 35 12.5 15 good year wrangler mtr's......
bally
Banned
so finally seperated the two thermostat housings and got them clean up at work today, new stainless hardware to go in as well.
just have to attack the ends where the corrosion has set in with some metal putty this arv then sand it all back again
80lover96gxl
She's s good lookin rig bally, be good to see it with the new rins n tyres, then some action shots when you get her on the road.
bally
Banned
Thermostat housings, new hoses, new fan and fan clutch, new 3 core copper brass radiator all installed today. Might make a start on the gauges tomorrow. Also need to order a new vdo oil pressure gauge and sender as the original has seen better days.
