GPS and ipad
oncedisturbed
If you have the 3g model then yes. If not you can get a receiver from the bad elf website that plugs in.
There are a few threads already on this if you have a gander with lots of info already posted by members
Tap, Tap Taparoo
red hilux
The real question should be, will the new ipad mini have gps. so far i havent foundcanything saying yes but its onky jyst been released so will get mire answer soon
The Mini is the same as the big one. Buy the 3G ( 4g??) one and you get GPS, Wifi only and you get no GPS.
It's got me stuffed why Apple persists with the old 4:3 format. Movies will be in miniature on that thing.
GPS Guru
You need one of these Bad Elf Ipad GPS - Handheld Systems it is a 10HZ device so it is very accurate and doesn't take long to log on at all. You can also power the Ipad off your cigarette lighter with it plugged in to the cigarette lighter socket. It comes with a mini USB lead but you'll need the plug for the socket if you want to run it off your car's system. If you just run it using the IPad's battery, then expect at least five hours. I got four and a half and ended up with 52% battery left but I didn't have the cellular data running and dimmed the screen a bit.
D Anderson
Have just done a trip over to WA ( from Sydney ) the Ipad with Hema app was brilliant,worked all the way we covered some 21,000 klms. Don't worry about a bracket as they are too cumbersome and restrict windscreen view . Buy a suitable protective cover to sit the ipad in ( a book type one with a flap )and use some adhesive Velcro to attach the back of the opening flap to the dashboard so the screen hangs over in front of the radio . It's very visible & out of the way and picks up the satellite signal just fine
GPS Guru
My understanding is that the builtin GPS is assisted GPS and uses a data connection via the mobile network to determine its initial position.
prawns
Wifi only models=no gps (triangulation only using data network mentioned above - it has no cellular capability so no "mobile" cell network lockdown at all? wifi only lockdown as far as im aware?)
3g/4g models = gps (assisted gps which is real gps but faster - uses wifi/cell signals for rough location if available to speed up the final satellite fix proper location lockdown - can be used accuratly outside of any network coverage)
D Anderson
Further to this confirming the Hema GPS app for the ipad picks up off satellite ( same as normal GPS units on the market ) , so you do not need to be within mobile range to receive like you do to receive / send emails etc . The Hema app is fairly cheap at around $200 for some 90 maps covering all of OZ .. When using the Hema if your doing a long trip you need to have the ipad plugged into your car power supply as it uses lot of power .
prawns
It will only " pick off the satellites" if you have a certain model iPad... Not all iPads have gps capability. The 3G model iPad does. The wifi only model doesn't
noel_c
Thanks everyone I think I will wait till apple release mini ipad next month which will come with GPS (WiFi- Celluar model only) I will then use memory maps
