Gme Uhf/cb Radio Install
FreshwaterAddict
Lads,
Just purchased a GME tx4400 uhf/cb radio with a Mobile one RF470FWSS 477mhz ground independant 6.5db gain UHF CB Antenna. Firstly just wondering what are your thoughts on this UHF/CB Radio and your thoughts on the Antenna?
How much range would you estimate i can get out of an antenna like this?
Now im an Electrician, not an Auto Electrician but i do understand it. I will be installing this sometime this week. Now i find it far more beneficial if i wire it up straight to the battery instead of to the ignition, makes things a bit more simplier also.
The only issue i have with installing this into my 04 Nissan Navara Dx 4x4 is where i want to install it. The UHF/CB Radio has a mounting bracket if i wish to mount it under the dash or on the centre console or what not. But ontop of my radio i have a compartment where this UHF/CB radio will fit.
For those who have a Navara will understand where this spare compartment is.
First question is how do i get the cable to where im going to mount the UHF/CB radio? Do i have to pull out my dash or is there a cavity? I have a spare hole in my firewall but its from once im in the car to run it up to where i want it to be installed.
Second question is the UHF/CB Radio comes with mounts. But im not wanting to mount it to the dash or under the dash i want to be installed into this spare compartment. I know to slide it in but how do i install it to make it stuck there so it doesnt move around or fall out???
Any help or pointers will be greatly appreciated guys!
NIAL8R
that whole surround that goes around your stereo, air vents and switches should just unclip just by getting a flat blade screw driver behind it and lightly prying it away till you can get your fingers behind it. thats what i can tell from looking at the pic's of one like yours. then if your going to run your cable for the ariel to the left side of the car just take the glove box out and you should have plenty of room to feed the cable behind the dash. Also if your UHF fits snug in the pocket that you want to mount it in, you should only have to cut the back off the pocket to get the face of the UHF to sit flush. while the dash cover is off fit up the UHF and you should be able to drill your holes and use the mounting screws that you got with it to hold it in place.
Also ( IMO ) i would wire it to ACC and not to the battery because if you forget to turn your UHF off you might wake one morning to a flat battery :( atleast if you wire it to ACC you know it will be off when the keys are out.
Hope all that mumbo jumbo helps :D
Watt
Im with NIAL8R, going to the ACC is easier anyway.. most radios have a fuse in the wire so you can simply tap into the 12V Cig lighter in your dash...
Getting the Antenna through your dash is simple, just start from the mounting location of your antenna and feed it along the engine bay and through one of the existing holes in the firewall.. there are usually 2 major ones with large rubber grommets. simply place a small cut in the grommet and feed the cable trough. if you reach up under the dash you will feel the cable coming through easily.. then just feed it along and over a few things to keep it out of the footwell and your in business.
Make sure to reseal the grommet with some silicon if you make the hole too big otherwise a deep river crossing might say hello to your feet.
As for the unit mount yeah just use the bolts that came with the mount and if the unit is too small for the pocket maybe attach it to one side of the pocket so it is flush at the face and one side.
Traveller
I wire mine direct from the battery, via fuse/circuit breakers etc. This way I don't need the key in to use the radio(handy at a campsite). This also allows me to run a decent power supply, dedicated to only the two-ways. Each to their own of course!!
NIAL8R
you have a good point there Traveller, i only say go through the ACC is because im the kind to get side tracked and foget all about it being left on :rollseyes: im pretty sure you could wire it up both ways by running your wires to 12v constant and splicing into the power supply on UHF side and use a Anderson plug so you can still use it without turning the ACC on. just have to make sure that a inline fuse is used :D
sdollery
In my Patrol I used a remote face unit, and built an extension cable for the face. Some 6 core telephone wire and some RJ connections. Some tape keeps it all together. I mounted the radio under the passenger seat and the face for the unit is mounted to the map lights in the mini-overhead console. The wire runs under the hood lining, down the pillar then under the door trim to the passenger seat. Looks neat and was dead easy.
