gearbox handbrake
BILLBY
hi guys this forum stuff is great my questions have been answered and now my truck is getting better , however being of the vintage of rear drum the handbrake just quite never holds and i can lift the brake a long way up ,SO having seen a handbrake disc fitted just after the gearbox and before the tail shaft which is out the mud and crap [fairly high in ours]how and where do i find info on this, i am starting my search here the truck is up on cribbing with the back end finally falling into disrepair ,the good lady drove the truck hard over the weekend LOL. pulled the hubs off and the pads needed replacing no doubt hence this question but the springs gave all they could so up the truck goes for a suspension rebuild . Has this been done to a sixties i would like to do this mod :cool:
MGWREF
1firefighter63, rear drum handbrake work well when they have been adjusted correctly. Have a go at this procedure. On the handbrake cable there will be an adjuster that loosens the handbrake cable. Either at the lever in the cabin or under the vehicle. Loosen the cable off completely. Then adjust the rear brakes via the adjuster wheel inside the brake drum so you can just hear the shoes touching the drums. Then re-adjust the handbrake cable so you obtain about 5 clicks. Re-check the rear wheel to make sure you can hear the brake shoes touching the drum when you rotate the wheel.
MG
BILLBY
yes
thanks for the reply. I managed to get the hubs off and I found lots of problems. 1 the hubs had been machined already leaving nothing left to machine. 2 the pads were dust,3 the adjuster arm on both wheels were bent and would not adjust either way[ still dont know why] so rebuilt it all including the thingy that pushes the pads out and as you guessed they work just great cost about $290 for the parts the labour I did myself all in all a good outcome :cool:
