Or,,,,,,,,,,,,,,,, I reckon it'll just turn if you twist it hard enough. (lefty loosey, righty tighty) Mind you, it's been there a few years. May come off in a few pieces.
I used to work at a caryard and have never seen a manual gearknob that didnt just unscrew (stock gearknobs anyway)
I used to have to remove them to detail cars - Some can be a right royal P$@% over time they seem to weld themselves on but should give eventually? (My 92 paj is a screwtype also just checked)
I hit a couple that had been glued on before (Guess the previous owner got sick of it not lining up)
My 87 swb paj, had a locking nut up underneath f***s me how it got there, but coundnt get it off, i unbolted the whole gear stick assembly from the top of the gear box, put the knob into the vice then just twisted, ended up just coming off. but that was an 87, havent had anything to do with a ng model. but the same theory would apply, if all else fails, you pick up a second hand gear stick assembly from the wreckers for 20 bucks
put a smal piece of timber on each side of the knob and then clamp a set of vice grips on the timber and give it a twist and it should free up. another thing to try is try and tighten it first then loosen it, i know it sounds stupid but it does work
i know about the tighten then loosen trick, used it a few times, i give it a go shortly, got the front sway bar bushes to do first. the back ones were a real pain.
