gear box overheating landcruiser 80
mighty
hi all,
I noticed that the case where the gear knobs is, get sometimes really hot and I can feel it with my left leg while i'm driving,particularly near the low gear box knob.
a friend advice me an oil coolant to add in front to the radiator as the transmission system is overheating.
any advice on the issue?
thank you all
4runnerSteve
At a guess its an automatic? And yes older automatics have a nasty tendency to get hot and sometimes need extra cooling. There should be two oil lines going into the bottom of the radiator, this is the factory transmission cooler. It is often inadequate for heavy use/offroad. If you are concerned first check the transmission oil is ok, then a transmission cooler is certainly worth considering.
4runnerSteve
Oh. That is a worry then. I'm not aware of a cooler for a manual, I know the hiluxes never had them not certain on a cruiser.
Maybe dump the oil and replace it with some really good mineral oil and some of that gearbox change smoothing stuff?
Past that I don't know
Aaron Schubert
The manuals don't have any cooling except the oil. I'd drain the oil and check the condition of it. If you are running the right grade of oil and its full, there's no reason why it would overheat unless something is wrong inside.
Mine gets warm too, but I've never checked the actual gear knob. It makes sense this would get warm though; it goes right into where the heat is generated.
Check your oil - maybe its the wrong grade, in poor condition or not at the right level.
Aaron
rogerazz
I drive a manual 91 Landcruiser Troopy. On hot days, say 34 degrees up on long trips, I get a lot of heat coming from footwell, hump along centre, gear stick etc.
It does tend to run hot although temp. is still good. Also wheels do warm up a little too. Also not great insulation from firewall, foot wells. etc. I then run the aircon.
