G'day From Hema Maps
HemaMaps
G'day Everyone.
Just thought I would say Hi from everyone at Hema. We have jumped on 4x4 earth to hopefully help out with any GPS / mapping questions and share our considerable knowledge on the subject.
We will also pop up in other places on the forum to throw in our 2 cents worth from time to time :)
But if you have any questions for us ether PM or even better chuck it up in the GPS thread.
So looking forward to having a chat to everyone and never hesitate to say G'day
Safe Journey...
Croozer
G'day and welcome aboard! I think you will get bombarded with questions on here! :eek:
Great to have you here! Have fun.....:D
Cheers Croozer
HemaMaps
Croozer, the more the merrier.
The more information that is out there the better it is for everyone involved :)
rob_macca67
OK then....Question Number One......
In regards to your Hema Navigator series GPS's.... When outback touring (ie outback and city touring holiday), Can you have one continual Tracklog file even when switching between the 2 operating systems (ie: Ozi and Igo).???
I had been told that u need to save you tracklog before u switch between the two systems.... is this correct?
rob
HemaMaps
Rob.
You are not able to have one continual track log as you are switching between 2 different programs. You dont need to save it each time you leave the program, but however long you are not in the 4WD program is the part that you wont have a tack log of.
Also if you have any more questions you should post them in the GPS section so that everyone can benefit from it.
poiderav4
Bathurst map
G'day Hema, I am from South Australia and recently took a trip in my RAV4 to Queensland and NSW I was planning a trip from Lithgow to Bathurst via Capertee and the upper Turon Valley, I got the route from this site and a book borrowed from my local library, I had a couple of maps and GPS coordinates but wasn't entirely confident so we stopped in at the Lithgow visitor centre to see what they had and found the Hema 'Bathurst Orange and Lithgow' map ist edition.
I knew the way from Lithgow to Capertee, so we stopped at Capertee to check the route once we got off road.
I was a little shocked that the Hema map (supposedly the best off road maps) didn't show the entire track.
According to your map the track stops after the Turon Gates and doesn't start again untill just into the Upper Turon Valley.
I have in car Sat Nav and it is virtually useless off road also so I was lucky to have a UHF and met up with some other 4x4 ers in the area and followed them through.
So my question is how can I trust a Hema GPS when the paper equivalent does not come up to scratch? I have asked in the GPS section on this forum for somebody to test a track that my GPS doesn't allow but the 64 people that have read the post have not replied so I have no comparison thus far.
Peter
HemaMaps
Poiderav4.
The Hema Bathurst, Orange and Lithgow is a city map and therefore was not designed with 4WD tracks in mind. That would be the most probably reason for the track not running the whole way through. It may also be possible that some of that track is in fact private property, which we are not allowed to map. In terms of the Hema GPS it comes preloaded with over 70 Hema 4wd and touring maps.
I had a quick look at your post in the GPS section and if you are able to attach the track that you were using then I am more then happy to test it for you.
rob_macca67
Rob.
Thanks for that.... Soooo the street side of navigating (Igo) doesn't allow u to record a Tracklog then ???
What is the file format then of the 2 systems (ie: Igo and Ozi). I'm used to garmin which is .gpx format.....
03hilux
Hi and Welcome to Earth.
I see it as a smart marketing move for companies such as Hema to jump on board these forums and see first hand feedback about products, and possible future upgrades the end user suggests to make more user friendly.
It is also a good way to squash rumours where they start.
Question. What Hema product would suit me best if I need a GPS unit for around town,used daily, and double as an off road unit for when i go 4wding?
Have you any free ones?:D
Regards
Roger
poiderav4
Poiderav4.
the track is on this site in the adelaide region and is called the 'Ashborne Haines Rd'
if you just put
start point as
corner of haines rd and Wattle flat rd Sandergrove
finish point as
Corner of haines rd and signal flat rd Ashbourne
Peter
HemaMaps
Poiderav.
Im not sure if I have done something wrong but I tried downloading the Ashbourne track twice (so i cant try anymore this week) and it has come up with a 404 error each time. I will try and see if im doing something wrong and try again next week :)
03Hilux, I would recommend the HN5i or HN6... Im sure I can get you one for free, as long as you give me $799 for free :D
poiderav4
Poiderav.
G'day, I have not tried to down load the maps at all as they are not compatible with the rav sat nav, I have only tried to create a track using intersections as start and finish points, I have driven the track several times now but not guided by the sat nav, I am just curious to know if the Hema GPS will let me create the track using intersections.
Peter
HemaMaps
Poiderav.
Sorry my misunderstanding. Ok I have tried it using our street nav system and it wont make the track down Haines Rd. I looked a little bit more into it and it would appear that there is in fact a small gap in the road for some reason where the data doesnt link up. I will be reporting that to Navteq so that it will hopefully be fixed up soon.
Safe Journey...
