G'day folks
rolux
Hi all
Been a member for a little while now but have only ducked in and out, yet to say hello.
Bought a 2000 hilux SR5 last november and have been along the beaches of SA, through Kosciusko and the Blue Mountains as long as some other random explorations in the Grampians etc. Few day trips here and there. Haven't modded anything really, just got myself a compressor, some tredz and a decent tyre deflator. Not at the stage where I can afford all the bits I'd like so no extreme stuff at this stage. Really enjoying exploring more of Victoria and being away from Melbourne whenever possible.
Inspiration came from a 6 month roadtrip up and down the west coast of the States last year, slept in the back of a Pathfinder. Was an awesome experience and racked up 26000km in that time.
Have added 12000kms to the Hilux since November and am now wanting to get a good mechanic to check out all the necessary things one should be looking at that don't appear to have receipts in the log book (valve clearance/fuel filter/water sedimenter (?)/brake fluid to name a few) etc. Anyone know of a reputable mechanic?? The last place I took it to for a service/safety check before the SA trip left the dipstick out....
TL;DR - hi, i'm new and have a hilux, where in melbourne should i get it serviced?
Rolly
rolux
Welcome to the forum mate,
I'm sure someone will recommend a mechanic!
Aaron
Thanks Aaron, fingers crossed!
Car is running beautifully and I'd be happy to do the oil change etc myself, I just know it could use a bit of a look over from a good mechanic, so hopefully someone knows of somewhere.
rolux
Hey mate
Had a look, looks like a good time. Unlikely I'll be able to in November for various reasons, but I may try and head over that way at some point to do some exploring. Cheers
Hilux is booked into Linea Rossa in Alphington if anyone's interested, research I did online suggested they had a decent rep and Jon seemed like a good bloke when I spoke with him. See how we go I guess, gotta start a relationship with a new mechanic at some point!
Welcome Aboard mate..
There a great vehicle, they can take you anywhere from standard really, buy a winch and you can usually get yourself out of trouble with the right recovery gear, tree protector, winch extension strap etc..Is it a petrol version.
rolux
Thanks Swaggie
Nah, 3L diesel version. Pretty impressed with the amount of terrain it's managed to take me through with zero mods. Winch would be nice for that piece of mind when out exploring by myself, but I've been told that ideally I'd want to replace the bullbar to a steel one first. Adds to the expense a fair bit. Any opinion on that?
Thanks Swaggie
Hi
I'd suggest you service yourself if you can.It's very easy..
I've used Penrite 15w50 for around 8 years.Change the oil filter every 2nd service although I've replaced every service.Fuel Filter every 20k and Air Filter depending on your driving 10_20k
Servicing should be every 5k
The fuel filter will have an electric screw on piece at the base, that's a buzzer for when it catches water..
Being fairly new I would drop all oils and start from new if their wasn't any book work, mine was vague so did the same..
Alloy Bar , some allow winches, others don't..Maybe weld a hitch receiver to the front of the vehicle, buy a winch cradle and winch, now you can winch from the front and rear once wiring is done using Anderson plugs...
Good luck
rolux
Thanks for the info Swaggie, much appreciated.
I am wanting to service the car myself eventually, but as this is the first 10k service since owning it (apart from a post-purchase, pre-trip service I had done), I am keen to get a qualified mechanic to check over some of the things that I have no record of having been looked after (for the most part, the service history and logbook is great, just a small stretch where the owner must've been servicing it themselves). I have spoken to the mechanic about this and asked if he can give me an idea of what can be done at home, so I'm hoping he is a good bloke willing to help me out with a list or similar.
I did the 5k oil change etc myself, was simple enough, I guess I'm just trying to get everything to a baseline that I can then work from in the future (hoping to own this one for a long time and am happy to maintain it properly)
Cheers for your help.
rolux
So if anyone is interested, got the car serviced for $240. That included a check of all the fluids etc I mentioned above, as well as the sedimenter and fuel filter. He wasn't concerned about valve clearances. Got 6.5L of oil, oil filter, new headlight globe, new wiper housing for that.
Not sure if you guys pay less anywhere else, but I was pretty pleased with it, and nice to know all is well after a pretty varied 10k.
I'll be trying to do most things myself from here, just gotta pick up a Gregory's manual.
krystac07
Hi all
G'day, I found myself needing a new 3D printer for my small business prototypes. My cautious attempts elsewhere had only resulted in minor wins that didn't help. Facing production delays, I discovered spinmama and decided to take a calculated risk. After several rounds of frustrating near-wins, I placed a larger bet than usual and finally achieved a significant win. This enabled me to purchase an industrial-grade 3D printer that produces perfect prototypes every time. My business productivity has increased dramatically, allowing me to take on more clients. It's worth remembering if you ever face similar business equipment needs.
Rolly View attachment 31773
hallo
