Hey Teza80 yeah your right thats slang and thanks every one what kind of 4x4 can i get for around 5k mark
I got my Patrol for 4,500. My brother got his TD Surf for 5k. Can get an aging 80s Landcrusher for around that much. Personally I'd go with either a Landcrusher or Patrol, the Solid front and rear is a lot easier to work with in my opinion, especially if you're looking to flex it up a bit at some point. IFS and IRS (which I don't think you can get in a 4wd) are a pain in the ass. You can get a Hilux with Solid front/Rear axles, not sure what age, and what model though.
Also, be careful about buying a 4wd with tonnes of mods, quite often if someone puts it on, they use it. And although it might seem like a bargain at the time, you could be buying a multitude of unknown problems. Much better to buy a reasonably stock car, and work your way up from there. And to clarify, having a bullbar and winch is nice, but if it's got insane amounts of suspension lift for cheap, don't touch it unless you can get it looked over by a mechanic. This is all common knowledge, but just in case
Apart from that, my personal rule: Stay away from cars that can be, or have been used as work utes/trucks - 9/10, they have been thrashed.
That's just my views, hope that helps you mate, I was new to this only recently, and I found getting a simple 4wd was better that going gung-ho straight out of the gate. I started with a WD-21 Pathfinder, worked well until I worked out what I wanted to do(and if couldn't do any of it
), hence my reason for suggesting a stock LC, great base to build off!
All the best mate, and welcome to earth!
